Cleaning out the garage and selling some misc parts
Bare 6-bolt block ( no crank, no BS, no front case ) $150
Used ( in good shape ) front case, oil pump, BS’s $50
1 set of 1G Manual cams $50
1 set of cams ( 2G exhaust, 1G Intake ) $50
1G BOV ( painted w/ clearcoat ) $50
Pair of 650lb Eibach springs ( normally 50 per ) $50
1G head with 1G cams ( needs an R&R and deck ) $150
3x Valve covers ( no cracks ) $40 each
2x Crank Pulleys $50 each
1G PS pump $25
DejonTool 1G BOV no leak kit ( regul $50 ) $40
Used 6-bolt water pump in decent shape $25
2x stock 1G SMIC $25 each
1G Fuel rail with 6AN fittings JBwelded ot ends $60
Stock GVR4 fuel pump $25
Stock 2G fuel pump $25
1G Exhaust manifold ( 1 in long crack ) $20
1G Alternator $50
Used 2100 ACT clutch with almost new disk ( some heat spots but straight and no cracks) $120
Cyclone Intake Manifold ( with working butterfly valves hooked to a 2G wastegate actuator ) $100
New In Box 2G (MB910562) Clutch Master cylinder ( missing push rod but you can just use yours ) $50
1G Intake Manifold $50
1G Throttle Body ( w/ FIAV but disassembled, no sensors ) $40
95-96 turbo ABS computer $150
6-bolt oil pan $60
90 Oil filter housing ( air to oil cooler ports ) $50
2 1/2" custom Aluminum TB elbow to fit stock 1G or 2G TB’s ( includes IAT boss ) $40
2x 1G coolant thermostat/water neck housings $10 each
2x 1G waterpipes for watercooled oil filter housings $20 each
Autometer boost gauge ( 20in vac -> 20psi boost ) $20
Shipping extra.
I have a ton of extra random parts so if you need something let me know and I will see if I have it.
