I’m cleaning out “some” parts I have at my parents house. LOL I have tons of car stuff. This is just 3800 serise II and III (95 97+) stuff. I’ve thrown out like 5 garbage cans, of 80-100K motor parts. And made 3-4 trips in my truck of scrap metal to junk heavy stuff. Stuff was fine, just needed to be cleaned, But I don’t have the time. I’m only keeping clean/new parts. But I dont need 4-5 of the same clean low millage parts. So these are good spare parts (no worn out junk) to get some more room. To nice to thow out. If you not local, Im not going to bother to ship out a $10 part so must buy a few little things then that add to Min $15.
PM’s list the parts is question is the title, and keep it there. And quote last/all Pms and replys so I can keep track of you, the parts, and the transaction. No dibs, unless your’ve bought more before or cool. If your a retard and can’t follow directions on getting me payment, I’m not gona sell it to you. Simple.
parts get updated as sold when I get payment.
Im a great seller.
http://www.clubgp.com/newforum/tm.asp?m=4127333&p=1&tmode=1&smode=1
http://www.clubgp.com/newforum/tm.asp?m=4139064&p=3&tmode=1&smode=1
http://www.clubgp.com/newforum/tm.asp?m=4354611&p=1&tmode=1&smode=1
O2 extension harnesses, 36inch extra long. $10 each
Custom steering column gauge pod. I made this from molding a normal 2 1/16th pod into a GP upper column trim piece. Also had the section it down for a shallower areoforce gauge, witch allows full tilt of the column with no contact to anything. And is positioned perfectly not to block anything on the dash gauges. Full speed view with only blocking the “1” is the gear range display, but I made sure the “2” is perfectly disable for roll racing ::): Paint matched, looks stock. Get this is ditch your gay Apiller gauges, and people stock asking you if you have a smaller pulley. If you take you GTP badges they think its extra slow.
ready for install. This took way to much time and effort to make, you can not buy anything like this for your GP. $50 FIRM
watch vids for better coolness.
3.8 pulley $15
GM SC belt PN 24507210 (6 rib 663) used 40K fits 3.8-3.4 pulleys $10
GM 3800 front cover gaskets $7 each
GM 3800 coolant temp sensor $10
GM 3800 knock senors $25 for the pair
GM 3800 cam senor $10
New GM never used 3800 flexplate, Drilled for 2 bolt patters 245mm, and 257mm convertors $40, lowerd to $35
New GM L67/L32 valve cover gaskets. GM lists at 37-45new. this set $25
New felpro L67/L32 valve cover gaskets with bolt gaskets. this set $30
GM 3800 lifter trays, clean low milage, no damage. $10 shipped US
3800 rockers, I don’t remember the year off these, But there clean, no oil staining, r wear on them. replace you dirty, hi millage ones $30
Drilled 160 Tstat, with good Oring $7
EGR “penny mod” block off plates. Have them for LIM, and rear mani $5 each
GM LS6 valvesprings, set of 16, low mileage off c5 z06 comes with the retainers $50 a set I have a few sets (aka: assload of springs)
Comp cams mixed 105/130 (6/6) The 105s (915) are new never installed. The 130 (918s) are were installed for only a few hundred miles, then removed to step down to the other 915 (new set). Both these are from a few years ago made PAC making them better then any current comp junk. I used the others of these sets on my car 11.4 M90 XPZ cam’d
New (never installed), and Like new (1-200 miles) asking $120 Now $110
Good soft 3800 Evap line SOLD
super clean 3800 crank sencore wiring cip thigher, no damage $5
same… ispection cover $5
same… SSEI M90 plug wire holder. Theses are nicer then the GTP/GS ones. SOLD
New NAPA front cotraol arm (rear) bushing. $9 each
Trans dipstick tube. Bent to work with TOG heads, has more room with a turbo DP also. clears the larger brake booster too. Has high temp pading to no cause fasle KR if your running non soild motor/trans mounts. Comes with level wand too. Great shape, no damage, rust or anything $40 Now $30
4t65 HD diff cover, replace you damaged or broken form a diff explosion. No damage, with good seal, and bearing. Super clean, like new $40 shipped US
oil pan, with gasket. Gasket wasn’t leaking, has windage tray. Pan is in great shape with no dents, rust or damage. It was professional washed out in a parts washer (the chalky color form the cleaner) ready to bolt on. $40
Eaton supercharger cuplar. Very clean, low millage still fits press tight. $12 shipped US
L67 SC belt idler stand, cleaned, and painted gunmetal. Ready to bolt on for you old damaged stripped, or L67 swap $7
O2 spoof works great no SES lights, theses are hard to find now. :snky: $40 Shipped US
Alt bracket/head hose, tensor housing. clean, painted gunmetal. Tenior is like new, only has about 24K on these. No correions, or stripped threads. Also is machined for added room for hi flow intercooler core fitting. $35 shipped US
New in box 3800 JP dual roller trimming sets $90
New Re usable rocker bolts, Info: http://www.zzperformance.com/grand_prix/products1.php?id=380&catid=104
http://www.intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=INT-RAB&Category_Code=HCV&Product_Count=3
These would cost you about $30 shipped.
Selling for $20 shipped (US)
ZZP/intense 2.60 SC pulley fits 6 and 8rib belts. SOLD
Great shape, like new belts. These are the best NAPA/gates Look at the lengths in the pics. 2 are 8rib, 1 is 6,
060670 - 68 1/8th long $10 shipped US
080680- 68 1/2 $25 shipped US
080730- 73 1/2 $27 shipped US
Don’t PM me if these will work on your car, look it up yourself. These aren’t for a stock 3800 so your gona need to know a little what parts you have, and what you need. Not all different brand belt PNs are the same measured lengths, no note what I listed there real lengths at.
I used them on all on a 2.2-2.3 thick IC core, 2.5-2.7 SC pulley. The 68.5 with the normal Wbody brackets. 73.5 with the SSEI brackets. Stock sized balancer. The 8 ribs are not cheap $4x new
trans external range switches. These get broke during motor and trans swaps. Good clean working ones. $10 each shipped US
GM oil level senors, good, clean low millage $7
3800 cam plates $7
3800 cam magnets $7
3800 ICMs $10
Good low mileage GM 02 sencor $20 Shipped US
m90 PCV cover $5 ?? free with other shit
CompCams retainers SOLD
DENSO 02 sencor. Like new, only a few hundred miles on unleaded pump gas. This in said be be fine with race gas. New there like $65 Looking to get $45 Shipped US
3800 timming cover, about 25K miles. Cleaned and painted gun metal, ready to bolt on no damage. Dosn’t not come with oil pump cover, but has gears and hardwear. $30
3800 timming cover about 84K miles., Needs to be cleaned, includes oil pump, and good water pump $40. Water pump seprate $20 Shipped US
Engine and trans mount braket. Very clean, ready to bolt on. Or a little time you can take a lot of weight out of them
$15 for the pair
GM sensors. Low milage clean, works great.
cam $20 Shipped US
crank $20 Shipped US
engine dogbones, Need to be cleaned, bushing look great no cracks or damage.
$25
Trans parts: everyting is 4t65e HD I cleaned up alot of spare trans, and extra part. Need to make some room. So these are up for sale, this is just what I have ready to sell, I took a pic of. I still have a lot of trans parts I need to go thu. Ask if you need anything, for your rebuild. Anything from bare case, to little part. Small parts add up anyting at adds up to like $20. I’d rather not waste the time to ship out a $10 part. Unless you have bought parts form me before. Or local pickup is always welcome.
HD output shaft. No damage, Like new. $25
trans pump, SOLD
Side cover gasket, Good non damaged. These new are somthing crazy like $85 new. Looks to get $30 for it.
Pan gaskets, these are good non damaged GMs I saved. Way better then a shit cork one if you dosnt have a GM on your car anymore. They are great gaskets are seal fine. Also new cost alot, $45 I recall. asking $20
Pump shaft. SOLD
Hardened 4th hub shaft. SOLD
HD diff cover (the one in the pic has some dirt on the outside). no damage. must have for you guys racing without a spotter every time
$50
HD diff cover, Not in pic I found this last night. Has some paint marks, Like form a rebuild shop. Its used But was presser washed, or steam claned or somthing Its very clean alum. $60
also has good VSS senors, and diff cover 0rings if you diff take out the Oring with the cover.
Extra new clutchs. Not everything for a full pac setup. But a must have for setting up you trans up tighter to hold more power. With adding a extra clutch, no wave plates ect. about 3-4 clutches/steels for each.
$15
Partial 3.69 single chain set. This is a bad ass upgrade, Zooomer went 9’s on this setup. I can’t find the drive gear, I hope it turns up. But its the good 7/8th stiff chain, Not the weaker “soft” 7/8 chain some people get. ZZP clains this chain is stonger then the 15/16th chain setup. And the moded gears to bolt in a 4t65hd. And a mint VSS wheel with no damage to the rivets to work with the drive gear. I forgot if I even ran this. It was probably just a back up, for a car I was setting up. Ill get a price tomorrow for full set, and with no drive gear.
trans pan, CLEAN, No dents, bends, rust or anything. $25
I forgot the right name, The drive carrier plant thing? But its the assembly that had the planets gear sets, that gets damaged when debris passes thru the trans fuild. Its mint, planets, and rings have no damage. I recall this part was like $130-$200?? maybe, there a chunk to replace. asking $50
Manual driver seat rack, this is hard to find. I used it to save weight over the power rack. bolts right in, $25
Drilled 180* Tstat SOLD
Drilled 160* Tstat $5
New Alum cradle bushings $15
NEW Timing chain dampener. SOLD
NEW GM Timing Chain, SOLD
PS pump, Off a 31K 3800. With pulley. The nipple off the res. is broke. So your have to use your current one. Its very clean, looks new.
$30
thanks
John
ADDED
2 1/16 autometer sport comp. gauges. All have bright white lights, with red covers. The senders, with wireing (vac T, and line for boost).
Boost 30/20 $30
Oil pressuer 0/100 $30
Trans Temp 100/250 $30
Another Good diff cover, has VSS $30
Good L67 ballencer $45
Low milage 6rib 660 belt $15
good 3800 starter SOLD
New unused 4T65HD borg. FWD band. $15
MINTset of GM HD AXLES!!! I bought these off a take off clip that had 25 miles on it!!! They still had a paper tags on them. I only ran these for half a summer, no rain. STOCK GM axles are the strongest, Ive never broke one. Just had a boot come off form worn motor mounts. But broke lots of after, market, and rebuilt axles. A1,cardone,ccw,napa maxdrive (the new replacments) These are what all the Big power race cars run. Just used good GM axles.
I just found them, thought I used them on a car. Car wasnt lowed. The look dark, because I sprayed them in wd40, so they didnt rust. And no flash. There were in sealed plasitc bags .
here is them dry
THEY ARE NOT the used cheap REBUILT, that you dont know if they have 250K miles on them. And remachined weakend parts. NO added $100-$150 CORE CHARGE on your credit card. No down time.
$250 (and you still have your set to sell to zzp for a $150 core, so you’d only have $100 into these)
97-03 grandprix
Good Lower dash knee panel $10
ever lower flet under cloum cover, with the light hole FREEE with $20 buy.
the gauge trim is sold.
Gauge cluster everything works $20
brentstrong hand job $5
