It is basically a 4 door ser with zero cop attention.
Car came with the low port SR20 non RR with 130km on engine aqnd body.
Since we’re promoting the the Ve one was swapped in.
Sr20Ve engine/maf/ecu/dizzy- only reused De part was the AC compressor.
SR16 ECU
Apexi VAFC with solenoids
Greddy Emanage
R5 STD coilover
custom JDM 2.5 exhaust front to back with cat modded to fit and Nismo Barrel in stealth black.
If interested please email
japanautosupply@hotmail.com
Riyad 416.894.9050
SR20VE
The 2.0 L SR20VE has Nissan’s Neo VVL variable valve timing with lift control. It produces 190 PS (139 kW) @7000 rpm and 144 ft.lbf (196 Nm) @6000 rpm and later (2001-2003) 205 PS (150 kw) @7200 rpm and 206 nm @5200 rpm. It does not have 20 valves as is sometimes stated. Used in the following vehicles:
