I have a set of brand new Skunk2 PRO Series stage 1 cams for all dohc vtec engines. They are new in box, still sealed. Specs are:
Pro Series 1+ Camshafts
IN 0.456,252 = 11.5824mm,252
EX 0.426,249 = 10.8204mm,249
I don’t have pics of the cams only because they’re still sealed in box, But if you want to see pics of the box, I will take pics.
Here’s a sample dyno graph with these cams:
200+ HP
MSRP: 700
I will take 550obo
what else do you need to run these on a stock motor?
laymone
4
You would probably want to raise compression with a thin oem gasket, and valvetrain to rev up to infinity
9.5k rpms
Bare minimum, you would want to do some fuel curve and ignition timing changes.
layzie
6
how are these big power cams? they are a stage 1, and dont have muchmore lift if any compaired to ctr/itr cams
kevin, these are PRO SERIES… not regular s2 stage1
If you look at the specs posted, they’re comparable to the regular skunk2 stage 3 cams.
According to the dyno graph, they actually make more power then buddy club stage3
layzie
8
i didnt see the pro series part
np, but if you’re in the 600hp club, you should know regular stage1 won’t make more then 200 hp
