2 10" JBL 300 watt subs
Bassworks Ported Sub box
Kicker 300.1 mono amp with bass control
Tsunami 1.2 Farad Cap - couple minor scratches
300 bucks for everything… firm. Save the comments, i dont need them
The system is wired in the vehicle still, and I have no problems showing you guys the system if your interested in buying. Bass sure hits hard for a tiny ass system.
Kicker 08ZX3001
Kicker 08ZX3001 300w 1-Channel Class A/B (Mono) Amplifier Model No. 08ZX300.1 Part No. 08ZX3001
Detailed Description of the 08ZX3001:
08ZX3001
Kicker 08ZX3001 300w 1-Channel Class A/B (Mono) Amplifier Model No. 08ZX3001 Part No. 08ZX3001
RMS Power Rating:
4 ohms: 150 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
Max power output: 300 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection
Preamp RCA outputs
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Fixed low-pass filter (80 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 25 Hz)
CEA-2006 compliant amplifier
Frequency response: 25-200 Hz
Dimensions: 13-1/2"L x 9-5/8"W x 2-1/8"H
8-gauge amplifier wiring kit recommended
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 150 watts x 1 channel
RMS Power (2 ohms) 300 watts x 1 channel
RMS Power (1 ohm) Not Stable
Bridged RMS Power Not Bridgeable
Peak Power Output 300 watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 1%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency Fixed (80 Hz)
Subsonic Filter 25 Hz
Signal-to-Noise Ratio 96 dB
Channel Separation N/A
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 50A x 1
an Ohm is a measurment of resistance in a closed circuit. its used in the formula V=AxR
where
V- Volts
A- Amps
R- Resistance.
or I=ExR simply repalcing the corrosponding values.
so for an example a 2 Ohms in a 12v circuit would be 6 amps able to follow into said Load.
lol. very pointless but i need to use my study material somwhere hahahahahha
