Kicker KX350.4 4 Channel Amplifier
This 4-channel workhorse is packed with the features you need, and you can trust that the CEA-2006 compliant power rating reflects a true measure of the amp’s capabilities. Kicker’s SORT protection circuitry safeguards against damage from short circuits, overvoltage, reverse voltage, or thermal overloads.
Variable filters may be set for high-pass, low-pass, or full-range operation so you can use the amp for different applications. Feel the need for some thump? The KickBass control lets you kick in up to 18 dB of bass boost at 40Hz.
- Used for 6 months
- a few scratches, but in overall excellent condition
- 4-channel car amplifier
- 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
- 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
- variable high-pass/low-pass filters (50-200 Hz, 12 dB/octave)
- variable bass boost (0-18 dB at 40 Hz) with wired remote level control
- speaker- and preamp-level inputs
- Tri-way capable (Tri-Way Crossover required)
- fuse rating: 20A x 2
- 8-gauge power and ground leads recommended
- 15-3/4"W x 2-9/16"H x 9-15/16"D
Asking $150.00
LIKE NEW Kicker 05DC122 Vented enclosure with dual 12" Comp subwoofers
This subwoofer system was used for 2 weeks and is in excellent condition, basically like new. It hits very hard, and is built very well, with two reliable Kicker Comp subwoofers in a well crafted Kicker built-to-spec vented enclosure.
- ported hatchback-style enclosure with two 12" Kicker Comp subwoofers
- 3/4" medium density fiberboard construction covered with gray and black carpet
- 2-ohm total impedance
- power handling: 300 watts RMS (600 watts peak power)
- frequency response: 20-200 Hz
- sensitivity: 99.9 dB
- 32-1/4"W x 16-1/6"H x 17-1/4"D1 x 14"D2
Asking $275.00
LIKE NEW - Kicker KS6.2 6-1/2" component speaker system
The Kicker KS6.2 component speaker system renders the low frequencies with light, yet rigid 6-1/2" woofers, suspended in vibration-dampening rubber surrounds. Sturdy steel baskets provide a solid housing with plenty of venting to keep internal parts cool.
Aluminum dome tweeters project the highs with authority, slicing through road noise to ensure lifelike stereo imaging. External 2-way crossovers provide a seamless transition between the woofers and tweeters  you’ll revel in detailed, realistic sound when you play your favorite tracks.
The versatile KS6.2 system includes mounting hardware for a variety of tweeter mounting options, or you can install the tweeters inside the woofers to create high performance 2-way speakers.
- Mid bass drivers used for 1 week, the rest of the items are BRAND NEW IN PACKAGE, NEVER USED!
- component speaker system includes woofers, tweeters, and crossovers
- 6-1/2" polygraphite woofer with Santoprene surround
- 1" aluminum dome tweeter with multiple mounting options
- tweeter may be mounted on woofer as a high-performance coaxial speaker
- external 2-way crossover (4000 Hz, 12 dB/octave high-pass, 6 dB/octave low-pass)
- marine ready with water-resistant mounting hardware
- power range: 6-75 watts RMS (150 watts peak power)
- frequency response: 35-21,000 Hz
- sensitivity: 88 dB
- top-mount depth: 1-15/16"
Asking $150.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
Thanks
