FS: Kicker Square Subwoofers, Kicker Amplifiers, Kicker 6.5" Components
LIKE NEW Kicker 06DS12L52 Vented enclosure with dual 12" Kicker L5 Solobaric subwoofers
This subwoofer system was used for 2 weeks and is in excellent condition, basically like new. It hits very hard, and is built very well, with two 12" Kicker L5 Solobaric subwoofers in a well crafted Kicker built-to-spec vented enclosure.
  • like NEW, IN EXCELLENT CONDITION!!!
  • Dual 12" Vented Sub Enclosure Loaded with 2 Solo-Baric 12" L5 Subwoofers
  • 3/4" medium density fiberboard construction covered with gray and black carpet
  • 2-ohm total impedance
  • power handling: 2400 watts MAX/1200 watts RMS
  • Embroidered Kicker logo
  • Oversized port
  • Combo vent/terminal cup
  • Dimensions: 16-3/8"TD x 19-9/16"BD x 32-3/8"W x 16"H
http://i6.photobucket.com/albums/y242/kingrukus/06DS12L52_1.jpg
Asking $500.00
Kicker ZX350.4 4 Channel Amplifier
If you’re into great sound, you’ll love Kicker’s ZX series amplifiers. These high-end amps set the standard for powerful sound, with a distinctive look that’ll make your installation stand apart from the crowd.
The built-in variable frequency filters adjust the amp’s output to get the most out of your speaker setup, whether you’re running full-range speakers or subs. Use the bass boost control to dial in the exact amount of low-end bump you’re looking for.
  • 4-channel car amplifier
  • 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
  • 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
  • variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
  • variable bass boost (0-18 dB at 40 Hz)
  • top-mounted controls
  • speaker- and preamp-level inputs
  • fuse rating: 20A x 2
  • 13-1/2"W x 2-5/16"H x 9-5/8"D
http://i6.photobucket.com/albums/y242/kingrukus/ZX3504_2.jpg
http://i6.photobucket.com/albums/y242/kingrukus/ZX3504_1.jpg
Asking $265.00
Kicker ZX1000.1 1000W Mono Amplifier
Kicker’s ZX series have been designed from the ground up to deliver tight, clean power. The ZX1000.1 efficient Class D circuitry allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with a variable crossover, high- and low-level inputs, and defeatable subsonic filter to help protect your subs.
  • Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
  • RMS Power Output - 1000 watts @ 2 ohms, 500 watts @ 4 ohms
  • Peak Power Output - 2000 watts @ 2 ohms, 1000 watts @ 4 ohms
  • Protection circuitry: Protects against short circuits, overloads, heat and reverse polarity.
  • Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
  • Variable crossover: LP(50 - 200 Hz)
  • Signal-to-Noise Ratio: 95 dB
  • Speaker and preamp level inputs
  • Bass Boost: 0 - 18 dB
http://i6.photobucket.com/albums/y242/kingrukus/zx1000_2.jpg
Asking $375.00
LIKE NEW - Kicker KS6.2 6-1/2" component speaker system
The Kicker KS6.2 component speaker system renders the low frequencies with light, yet rigid 6-1/2" woofers, suspended in vibration-dampening rubber surrounds. Sturdy steel baskets provide a solid housing with plenty of venting to keep internal parts cool.
Aluminum dome tweeters project the highs with authority, slicing through road noise to ensure lifelike stereo imaging. External 2-way crossovers provide a seamless transition between the woofers and tweeters — you’ll revel in detailed, realistic sound when you play your favorite tracks.
The versatile KS6.2 system includes mounting hardware for a variety of tweeter mounting options, or you can install the tweeters inside the woofers to create high performance 2-way speakers.
  • Mid bass drivers used for 1 week, the rest of the items are BRAND NEW IN PACKAGE, NEVER USED!
  • component speaker system includes woofers, tweeters, and crossovers
  • 6-1/2" polygraphite woofer with Santoprene surround
  • 1" aluminum dome tweeter with multiple mounting options
  • tweeter may be mounted on woofer as a high-performance coaxial speaker
  • external 2-way crossover (4000 Hz, 12 dB/octave high-pass, 6 dB/octave low-pass)
  • marine ready with water-resistant mounting hardware
  • power range: 6-75 watts RMS (150 watts peak power)
  • frequency response: 35-21,000 Hz
  • sensitivity: 88 dB
  • top-mount depth: 1-15/16"
http://i6.photobucket.com/albums/y242/kingrukus/ks62_1.jpg
Asking $150.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
Thanks
Kicker ZX1000.1 1000W Mono Amplifier Sold!
Rest of items are still available.
Kicker 06DS12L52 Vented enclosure with dual 12" Kicker L5 Solobaric subwoofers sold!
Kicker KS6.2 Component Speakers sold!
Kicker ZX350.4 4 Channel Amplifier available, price negociable
