LIKE NEW Kicker 06DS12L52 Vented enclosure with dual 12" Kicker L5 Solobaric subwoofers
This subwoofer system was used for 2 weeks and is in excellent condition, basically like new. It hits very hard, and is built very well, with two 12" Kicker L5 Solobaric subwoofers in a well crafted Kicker built-to-spec vented enclosure.
- like NEW, IN EXCELLENT CONDITION!!!
- Dual 12" Vented Sub Enclosure Loaded with 2 Solo-Baric 12" L5 Subwoofers
- 3/4" medium density fiberboard construction covered with gray and black carpet
- 2-ohm total impedance
- power handling: 2400 watts MAX/1200 watts RMS
- Embroidered Kicker logo
- Oversized port
- Combo vent/terminal cup
- Dimensions: 16-3/8"TD x 19-9/16"BD x 32-3/8"W x 16"H
Asking $500.00
Kicker ZX350.4 4 Channel Amplifier
If you’re into great sound, you’ll love Kicker’s ZX series amplifiers. These high-end amps set the standard for powerful sound, with a distinctive look that’ll make your installation stand apart from the crowd.
The built-in variable frequency filters adjust the amp’s output to get the most out of your speaker setup, whether you’re running full-range speakers or subs. Use the bass boost control to dial in the exact amount of low-end bump you’re looking for.
- 4-channel car amplifier
- 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
- 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
- variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
- variable bass boost (0-18 dB at 40 Hz)
- top-mounted controls
- speaker- and preamp-level inputs
- fuse rating: 20A x 2
- 13-1/2"W x 2-5/16"H x 9-5/8"D
Asking $265.00
Kicker ZX1000.1 1000W Mono Amplifier
Kicker’s ZX series have been designed from the ground up to deliver tight, clean power. The ZX1000.1 efficient Class D circuitry allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with a variable crossover, high- and low-level inputs, and defeatable subsonic filter to help protect your subs.
- Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
- RMS Power Output - 1000 watts @ 2 ohms, 500 watts @ 4 ohms
- Peak Power Output - 2000 watts @ 2 ohms, 1000 watts @ 4 ohms
- Protection circuitry: Protects against short circuits, overloads, heat and reverse polarity.
- Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
- Variable crossover: LP(50 - 200 Hz)
- Signal-to-Noise Ratio: 95 dB
- Speaker and preamp level inputs
- Bass Boost: 0 - 18 dB
Asking $375.00
LIKE NEW - Kicker KS6.2 6-1/2" component speaker system
The Kicker KS6.2 component speaker system renders the low frequencies with light, yet rigid 6-1/2" woofers, suspended in vibration-dampening rubber surrounds. Sturdy steel baskets provide a solid housing with plenty of venting to keep internal parts cool.
Aluminum dome tweeters project the highs with authority, slicing through road noise to ensure lifelike stereo imaging. External 2-way crossovers provide a seamless transition between the woofers and tweeters — you’ll revel in detailed, realistic sound when you play your favorite tracks.
The versatile KS6.2 system includes mounting hardware for a variety of tweeter mounting options, or you can install the tweeters inside the woofers to create high performance 2-way speakers.
- Mid bass drivers used for 1 week, the rest of the items are BRAND NEW IN PACKAGE, NEVER USED!
- component speaker system includes woofers, tweeters, and crossovers
- 6-1/2" polygraphite woofer with Santoprene surround
- 1" aluminum dome tweeter with multiple mounting options
- tweeter may be mounted on woofer as a high-performance coaxial speaker
- external 2-way crossover (4000 Hz, 12 dB/octave high-pass, 6 dB/octave low-pass)
- marine ready with water-resistant mounting hardware
- power range: 6-75 watts RMS (150 watts peak power)
- frequency response: 35-21,000 Hz
- sensitivity: 88 dB
- top-mount depth: 1-15/16"
Asking $150.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
Thanks
