FS: Kicker Resolution 6.5" Components & Kicker ZX460 360wRMS 4 Ch Amp
Kicker ZX460 4 Channel 360 Watt RMS Amplifier
This is an incredible “old school” amp that I actually purchased brand new in 2004. It is the last of Kicker’s brutally strong amps, and is in excellent condition. These things were built like tanks.
As seen below, this amp actually was benchmarked by kicker to output 414 watts RMS.
This amp is very versatile as it can run at 4ohm, 2 ohm or 1 ohm stereo and down to 2 ohm mono.
Full Amplifier Manual in PDF Format: http://www.kicker.com/06/tech-support/manuals/manuals/ZX460AmpMan.pdf
- 2-, 3-, 4-channel output
- 30 watts RMS x 4 at 4 ohms
- 60 watts RMS x 4 at 2 ohms
- 90 watts RMS x 4 at 1 ohm
- 120 watts RMS x 2 at 4 ohms in bridged mode
- 180 watts RMS x 2 at 2 ohms in bridged mode
- stable to 1 ohm in stereo, 2 ohms in mono mode
- frequency response 10-28,000 Hz
- MOSFET power supply
- requires 8-gauge power and ground leads
- rear channel switch able high-pass crossover (100 Hz at 24 dB per octave)
- discrete output transistors
- silent turn-on/off circuitry
- removable end-caps
- 14-9/16"W x 3-1/16"H x 10"D
Actual pics:
Some paint chipping on one end cap:
Asking $230.00 CDN. Shipping extra, and I can meet in the GTA.
Kicker Resolution RS6C 6.5" Component Speaker System:
The Kicker Resolution RS6c component system consists of a trio of separates — silk dome tweeters, titanium-plated polymineral cones, and precision 2-way crossovers — that will enliven and enrich every facet of your music. You’ll be knocked out by the three-dimensional sound quality.
- Separate or Integrated Coaxial Tweeter Mounting, all required hardware included to mount various ways
- 6 1/2" Mid Bass Speakers
- depth 2-1/2"
- 1" Impregnated Silk Dome Tweeters
- Original wiring included
- Sensitivity: 87 dB
- Frequency Response: 40-22,000 Hz
- Recommended RMS Power: 100W
- Peak Power Handling: 200W
- Titanium-Coated Polymineral Mid-Bass Cones with Cast Aluminum Mid-Bass Baskets
- High-Temp Kapton Voice Coil Formers
- Butyl Rubber Surrounds
- Ferrofluid Cooled, Neodymium Tweeter Magnets
- Variable Tweeter Attenuators
- Integrated Illuminated Tweeter Protection Circuits
- Surface or Flush Swivel Tweeter Mounting Hardware
- high-quality two-way crossover (3,500 Hz, 18 dB/octave) includes variable tweeter output control
- Impedance: 4 ohms
- An innovative tweeter mounting post even lets you mount the tweeter directly to the center of the mid-bass for an instant top-notch coax! It’s the ultimate in high-end systems. Includes surface and recessed swivel tweeter mounting hardware and grilles.
Actual Pics:
One Tweeter Mounting cup edge slightly broken, but easy to find replacements if you want:
Asking $180.00 CDN. Shipping extra, and I can meet in the GTA.
Please e-mail me at paradigm905@hotmail.com or PM me if you wish to purchase.
