okay my shop is full of S13 parts and it looks like an auto wreckers, there are 5 of the cars sitting at the shop. parts and cars need to get finished or get stripped and sent to the wreckers. most of these parts are mine so they have a price posted, some of them are my buddies’ so i’ll have to converse with them before posting a price, but i will post prices for everything that isn’t listed as soon as i can.
if you need any S13 part, ask me and i probably have it and i will update this thread as i find/remember more parts.
if you’re buying multiple parts, deals will be worked out! need to get this stuff sold
everything is located just outside of Ayr, Ontario, which is a small town near kitchener/waterloo & cambridge. i live in london right now so delivery there is easy. my buddy who owns a lot of these parts works in guelph so delivery to there is possible. delivery to other areas will cost extra, meeting up half way will not.
Engines & engine parts:
-complete '89 SOHC engine w/ accessories, 160,000km. couldn’t get the engine to run properly, not sure why but we suspect bad gas, engine was pulled because a DOHC was put in
-complete '92 DOHC engine w/ accessories except distributor, engine runs well, car was in a front end collision so the distributor is smashed
-alternator $35
-SOHC power steering pump - $20
-SOHC intake manifold - $20
-SOHC fuel rail and fuel pressure regulator $10
-SOHC fuel injectors - $20 for 4
-SOHC complete cylinder head, a couple exhaust manifold studs are stripped though $20
-SOHC block & internals, ran strong and had good compression, engine was pulled because a DOHC was put in $50
-A/C shit, give me some pocket change and take what you want, we have pulled the A/C out of 3 cars, soon to be 4 so i have an insane amount of A/C parts kicking around
-SOHC stock intake, airbox and filter, without MAF $20
-random collection of emissions equipment $cheap
-SOHC distributor, cap & rotor $30
-starter X2 $30 each
Drivetrain:
-complete 5 speed swap $350
-SOHC auto tranny $30
-torque converter & flex plate $10
-open diff $20
-open diff axles $15 each
-automatic driveshaft $10
Steering/suspension/brakes:
-calipers from an ABS car $20 each
-MC from an ABS car $30
-brake booster X2, one ABS, one non ABS $20
-stock suspension, not blown (springs & shocks) $50
-set of 4 tear drop wheels with bald tires $60
-set of 4 7 spokes with tires (will have to check tread life before posting a price)
-all hicas parts $varies
-all suspension parts like control arms, hubs, spindles, etc $varies
-steering rack $50
-steering column with key X2
Electrical:
-SOHC engine harness uncut $40
-SOHC engine harness butchered $5
-SR20DET engine harness butchered
-SOHC 5 speed ECU X2 $20 each
-3 peice tail light set for a hatch back X2 $40
-SOHC MAF X2 $30 each
-DOHC MAF
-DOHC 5 speed ECU
-SOHC gauge cluster $30
-DOHC gauge cluster $50
Body:
Parts from a black '90 hatch, base model:
-passenger door, no rust but some dents, no power options $20
-drivers door in ok condition, no power options, minor S13 rust bubbling starting under the mirror, 1 small dent that i noticed $20
-drivers side manual mirror, mint $15
-passenger side manual mirror, mint $15
-door glass, tinted $20 each
-rear quarter windows, tinted $15 each
Parts from a gold (champagne) '92 hatch, fully loaded:
-drivers door, great shape, all power options
-passenger door, great shape, all power options
-rear bumper
-manual sunroof
Interior:
-rear view mirror X2
-brown HUD projector
-brown dash X2
-brown carpet X2
-brown leather rear seat
-brown door panels, all options
-black door panels, no options
-89-90 syle cloth passenger seat in good shape $10
-plastic bits from around the dash/steering wheel/gauge cluster $varies
Other:
-fuel pump & sending unit X2 $30
-gas tank X2 $50
CONTACT:
you can either PM me or jowo72 to set something up. my PM box gets full on a regular basis so if you cannot contact me through that, then send me an email or add me to msn - drewbrend[at]gmail[dot]com
thanks all.
