Receiver:
HK AVR230
● Codecs: DD, DD EX, DTS, DTS ES, DTS
Neo:6, Logic 7
● 6 amplifier channels, 50 Watts/Ch
● 7.1 Pre-Outs
● Dual Power Supplies
● 6 Digital Inputs
● 2 Digital Outputs
● 2 component video inputs
● Triple Crossover Bass Management
● EzSet Programmable Remote, With Macros
● Dimensions: 6 5/8” H x 17 5/16” W x 15” D
● Weight: 28 Pounds
● MSRP: $799
Surround Speakers/Subwoofer:
HK HKTS6
- 8 Ohms nominal impedence
- 86dB @ 1 watt/1 meter sensitivity
- One 1/2" dome, video-shielded tweeter
- One 3" driver, video-shielded midrange driver
- Dimensions: 4-5/8" x 3-1/8" x 3-3/4"
- Weight: 1.1lbs
- Center Channel
- 10 70 Watts Recommended Power Amplifier Range
- 8 Ohms nominal impedance
- Dual 3" drivers, video-shielded midrange
- Dimensions: 3-1/2"X 7-5/8" X 3-3/4"
- Weight: 1.89lbs
- 100 Watts Recommended Power Amplifier Range
- 10" Woofer, bass-reflex enclosure bass driver
- Dimensions: 15-3/4" x 15-3/4" x 16-3/4"
- Weight: 33.5lbs
- 100-Watt bass-reflex powered subwoofer with 10" driver.
- Four identical satellites with dual-driver, voice-matched center handle up to 70 watts of power.
- The satellite and center speakers are magnetically shielded.
- Includes wall-mount brackets for satellites and all needed cables.
- Color-coding system for speakers and cables simplifies proper installation
- satellite speakers are included.
- MSRP $599
All used very little and lightly on the exception of the occasional rock band fest…i still have the original boxes for all of these
$500 obo
