walbro 255 in-tank fuel pump - $55
aeromotive FPR w/ fittings, hoses, 3/8 steel return line, and AN fittings to plumb the larger return into the top of the fuel pump housing … only needs your own style fuel rail adapter, unless the one we have fits your car (made from the stock fpr for the 3g eclipse) - $120 for everything - $95 for the FPR alone - free install if the price is right
1g dsm metaltop BOV - never crushed -$25
1g/2g cast manifold - $30
dsm 440 injectors, dsm resitor pack, dsm injector clips, injector harness all soldered and taped up, just ned to hook up your injector wires to it - $50
Intercooler, cannot remmeber exact dimentions. 2g DSM FMIC design, 3’ out (Have reducers to 2.5)
14b turbo - decent shape - nothing pretty but works great - great for stock replacement on the cheap - needs wastegate actuator unless i have a spare one laying around - $60
SAFC … great condition, might even have the book for you $125
innovative lc-1 wideband, works perfect, has the firmware updates, still have the box, unused bung & bung plug if i can find them … one of the analog outs is already set up to provide a false stoich mixture signal to the ECU for the sake of letting the ECU tune itself for 12.5:1 in closed loop mode - SOLD
we have a set of 3g eclipse intercooler piping, needs a turbo intake pipe as the one on the car is not that pretty… $$make offer
SPEC stage 3 clutch for the 4g64 engine … NEVER USED … My cluch never blew … so there wasnt yet a need to install it - $$ make offer
turboXS manual boost controller, never used as i didnt want to take the boost over 9psi anyways. -$40
-I also have a vortec 10:1 ratio FMU w\ fuel lines that was bought used, but i didnt need it as i decided to go FPR+safc instead of a rising rate unit. - $50
-autometer pyrometer EGT w\ sensor and all wires - SOLD
-autometer phantom A\F gauge -$40
-VDO boost gauge~shows boost 0-30 but does not show vacuum.- $10
-3 pillar generic gauge pod - not made for any specific car - fit mine 95% w\ almost no mods, juse removed the clips from my original pillar and applied to this one, never has fallen or or failed on me. - $15
