I know this is the wrong place but I am just posting this, I upgraded to krell so this need to go
NAD 1240 Pre-amp
Pre-Solid with mc, bass eq circuit
couple small scatches from being stacked
$100
Integra (Onkyo) AMD 2.1
Power Output 2 x 125 watts/channel into 6 ohm 105 into 8 ohm RMS
8 ohms 2 x 140 W
THD 0.08 % at rated power
IM Distortion Rated Power 0.08 % at rated power
Damping Factor 100 at 8 ohms
Frequency Response 10 Hz to 100 kHz: ±1 dB
Signal-to-Noise Ratio 110 dB (IHF A, 0.5 V input)
Dimensions (W x H x D)
Inches 17-1/8" x 5-11/16" x 12-7/16"
Weight 18.7 lbs
$200
plus actual shipping from 33705
