FS: Nitrous kit
For sale,
Zex Nitrous kit, dry shot, universal fogger, 55-75hp. Can be used on 4, 6 or 8 cylinder cars, just need to use the correct jetting chart for each. Will be coming with an Edelbrock bottle, not the Zex bottle that came with the kit. I also have the jets for a 100 and 125 shot that will come with the kit. Part #82011
$350 obo
82021 is a wet kit.
82011 is a dry kit.
I assume you meant the latter?
Yes, my bad, fixed…
interested was this on ur mustang. cause i have a 4.6 i might wanna put this on so would u have the jetting stuff for it.
yes this was on my car. i’m sell it because I switched to a wet kit
hey can I take a look at your car, have/take a ride? I’m really thinking going the nitrous route instead of SC again. Very interested!
Also, any additioinal parts? WOT switch, window, etc.
edit: I’m in OP by the way
Sure you can, but right now the car is on jack stands with the tranny in alexander getting a harden gear set put in it. the car should be out by mid april wit the new nitrous.
I’ll give you a ride when its done no problem. I’m keeping my window switch and bottle heater adn purge since i’m still runnign nitrous. The only extra item I have is a new in box NX remote bottle opener that idk if I want to sell or keep.
The Zex kit comes with a “brain box” that has a built in WOT switch that your use by tapping into a wire on your TPS(throttle position sensor)
when can i check this out i am also in west seneca
give me a call i’m home the next 4 days, 713-1174
ok i will tomorrow i get outa work at 4
sounds good
bump
If this was a wet kit i probably would have grabbed it. :frowning:
bump
bump
ttt
ttt
