FS: parts only - small 16g
compressor housing- previous owner “ported” it, so theres some 80? grit sand scratches on the inducer side, looks shitty but isnt hashed. if anyone wants it ill throw it in the lathe and smooth it back out by hand
no marks from the compressor wheel (surprisingly)
no porting work was done anyplace past the leading edge of the wheel, or on the outlet side
center housing - bearings are fried, but no stripped threads on the oil / ater passages
exhaust housing- normal cracks that youll see on an abused turbo, but if u want it …
wastegate actuator - it works, its clean looking, what more do you want to know ?
turbo is currently apart because i had to pull the exhaust housing to remove the one oil fitting, and because i wanted to inspect the carnage. if anyone wants pics i can snap some webcam pics for ya
how much do you want
