This is mainly geared to those of you who already have larger front caliper’s and rotors.
It was mentioned in the 5 Bolt Conversion thread but I thought it may be better to start a seperate post for this.
You get larger Rear Caliper’s, Rear Rotor’s, Brake Lines, E Brake Cable, Spindles and knuckles. As well you will get Front and Rear 5 Bolt Hubs which you can either put on now or later. So baiscly this is the same kit minus the front brakes. It will bolt right up to your stock control arms.
The price is $750.00, NO TAX, and includes your SON’s 15% discount.
For those of you planning to track you car this will be a great compliment to your larger front brakes. We all know that most of the braking is done up front but having better rear’s will take some of the pressure off. Plus if you plan on using a Brake Bias Controller, again the bigger rears will be benifical for making a very good all around brake system. Which is usefull on the track.
Hey, are you ever going to be selling just the hubs? The reason I’m asking, is since I want to do the conversion to run better rims, and I don’t really need better brakes right now on my bone stock car that never sees any track duty.
This is just a SINGLE POT REAR upgrade kit with REAR ROTOR’S, REAR LINES, E BRAKE CABLE, SPINDLE’S, KNUCKLE’S, FRONT SPINDLE’S, KNUCKLE’S and ALL 4 HUBS. This kit does NOT come with front caliper’s or rotor’s. That’s what you would get for the $750.00.
These are EXACTLY the same as the 300zx conversion. The R32 Skylines, S15’s, S14’s and the 300’s all share the same equipment when it comes to the brake system’s.
So if your waiting or looking for a 300zx conversion, grab this or one of the 5 Bolt/Full break kits. These are the same .
Avery - Well at this point we are not parting out the kits for just the hubs alone. Sorry man. Keep in touch with me though as this may change in the future.
im asking because i was under the impression only s14 hubs worked on the front for 5 lug swap
so looked to me like these front hubs will not work[/quote]
No as with all the cars mentioned above, all the hubs are the same. Well with the exception of ABS cars. I don’t think ABS and non ABS hubs are interchangeble.
