UPDATED/CONSOLIDATED LIST
Delivery is available on everything over 100$. Parts are located just outside of milton.
Contact:
Mark (905) 719-0978
Brenden (519) 242-3965
Blacktop S13 SR20DET motorset. COMPLETE SWAP. (Minus clutch)
SMIC, 5-speed, t25 (some play), CURRENTLY RUNNING. Megan DP, HKS wastegate actuator.
1800$ (free delivery in the GTA if purchased this weekend)
OPTIONS-
$250 - Koyo aluminum radiator w/ Flex-a-lite electric fan
$300 - ACT 6 puck unsprung clutch ~ 10,000km, great shape
$80 - Short shifter
$80 - Apex’i Intake
$80 - Megan 3" downpipe
$250 - Custom FMIC setup, smaller core that fits under unmodified re-bar, piping powdercoated black with HKS SSQ bov
$800 - Tien coilovers - fronts are basics with camber adjustable pillow ball mounts, rears are “control master” type flex, great condition
$120 - Megan adjustable rear upper control arms with about 200km on them
$350 - 5 Lug conversion, S14 front hubs, LCA’s and lower strut bolts, Z32 rear hubs, needs one rear wheel bearing
$80 - Front & rear strut bars - no brand name.
$700 - R32 Skyline GTR wheels, 16X8 +30 offset - one rim has some very slight curb rash on the rim, other than that the set is in very good condition
Front tires: Dunlop Direzza Z1 star spec 205/50R16 - still look brand new, 90%+ tread left
Rear tires: generic Goodyear eagle 205/50R16 50% tread
Stern Inter Touring 17x7.5 +48ish Including 2x1", and 2x1.5" spacers. 5x114.3 bolt pattern. With Kumho tires, 70% tread. (600$)
Knock-off Volk CE28 17x7 +35ish (300$) two tires with 20% life, 2 dead.
$600 for the full swap
Z32 300ZX aluminum calipers, powder coated fire engine red
Z32 300ZX stock pads and rotors - might need pads for one side in the rear due to the bad wheel bearing.
Z32 2+2 e-brake cables with extensions to make the e-brake work
Z32 brake master cylinder included. without this the brake pedal is soft.
1.8t VW parts: FULLRACE top-mount turbo manifold, FULLRACE downpipe with flex. (1500$ for all three, 600$ each seperate)
1 piece exhaust from the downpipe to the tail pipe. piping looks to be 2.5". cat is hollowed out, straight through. exhaust doesn’t have any leaks and uses 3 stock exhaust hangers. sounds pretty good. perfect for an SR swap or KA-T on a budget. bolts up to the stock O2 housing. O2 housing not included (100$)
2 sets of silvia projector lights. With corners. (150$)
Carbon Autometer gauges. Legitimately nice. Nitrous Pressure, A/F Ratio, Fuel Pressure, Boost. With REAL carbonfibre mounting pods. (400$)
Random Defi Knock-offs. Two boost, One Volt meter (80$ all three)
Defi Knock-off Oil pressure, with sender (50$)
Defi knock off Air/Fuel gauge, works great, looks good. (50$)
AutoMeter Oil pressure Gauges. 1 carbon(60$), 1 procomp(30$ No sender).
Pioneer MP3/CD decks (60$) Your choice ONLY ONE LEFT
Kenwood Amp (30$)
Authentic Nardi Wood wheels. 1 small (200$), 1 big (180$)
Momo GNARLY WHEEL (120$)
Cusco Knock-off front strut bar (40$)
Rotora DRY CARBON GT WING. BRAND NEW. No mounts. (700$)
Nitrous Express System. Tank, purge valves WITH SWEET LED’S, intercooler-cooler, AN- lines. (500$)
OMP race bucket. 1 small hole, needs a cleaning. (500$)
Sparco Sprint Knock-off. No rips, great shape. (350$)
Yonaka Reclinable racing seats. No tears. MINT SHAPE
(800$)
S13 ARP extended wheel studs. they are not the stock thread, they are honda thread and use 19mm lug nuts which are included with the studs. the knurl is the same however so they work great. 2.5" long (80$)
MAKE SOME OFFERS. NO REASONABLE OFFER REFUSED.
