SDS Standalone Engine Management for 6 cylinder Engines. This system was on a VW 12v Vr6 but could work for almost any 6 cylinder engine.
-EM4-6F System
-Currently setup with a conservative tune for a VW VR6 Turbo (TO4E)
-Has Version 12 software and can be upgraded, if you want
System Includes:
- ECU
- LCD programmer
- Air temp sensor
- Water temp sensor
- Main wiring harness
- Injector harness
- Fuel trim control
- Crank sensor
- Timing magnets
- Coilpack
Included SDS Options:
-Fast Idle
-Fuel Pump Relay
-Radiator Fan Control
-3 Bar MAP Sensor
Also Included:
-New Accel Braided Spark Plug wire set (Cut to fit)
-Bracket for mounting Crank Sensor to VW 12v Vr6
-VW 12v VR6 Crank Pulley with magnets installed (not pictured)
SOLD
