The monitor is in working condition i have 3 plasma this one has to go. its only a monitor so you will need external speakers.
the only minor problem i can tell is that when you plug a monitor in to it the task bar on vista deskto flickers. its hard to explain, its completely viewable just makes the tas bar look like glitter. its happens on and off.
here are the specs
lat Panel Type Plasma Television
Screen Size 42 inch
Contrast Ratio 900:1
Digital TV Standard EDTV-Ready Television
Display Resolution 852 x 480 pixels
Digital TV Standard EDTV-Ready - Requires separate receiver to view EDTV signals.
Broadcast Format Displayed 480p (EDTV) • 480i (SDTV)
Broadcast Format Supported 1080i (HDTV) • 720p (HDTV) • 480p (EDTV) • 480i (SDTV)
Built-in Tuner NTSC • PAL • SECAM
Native Aspect Ratio 16:9
Interpolated Aspect Ratio 4:3
Pixel Pitch 1.08 mm
Brightness 490 cd/m²
Output Color 16.8 million colors
Viewing Angle 160
Adjustable Color Temperature Without Adjustable Color Temperature
Remote Control Standard
Illuminated Remote Non-Illuminated
Audio Type Stereo
Picture in Picture With PIP
Sleep Timer With Sleep Timer
Rear Input Connectors S-Video x 1 • Composite x 1 • Audio (RCA) x 1 • 2 x D-Sub (RGB PC)
Rear Output Connectors Composite x 1
Headphone Jack With Headphone Jack
OSD Languages English • German • French • Italian • Spanish
Closed Caption on Mute With Closed Caption On Mute
Number of Speakers 2 Speakers
Speaker Power 2 x 7 Watt
Width 40.75 in.
Depth 3.4 in.
Height 24.88 in.
Weight 59.5 lb.
Overall Warranty 2 Years
Cabinet Color Black • Silver
Included Accessories Remote Control Batteries • DVI Cable
MPN pfm-42v1
Product ID 21304943
