Here are some parts that are left over from my SR swap
Stock KA24DE Exhaust including CAT
Catback was purchased 1 year ago this month, and used until Nov. (car went into storage). The is CAT pretty much NEW, it was purhased this year in March right after I took the car out of storage, it was used to pass the E-Test and then the SR swap began, all together it has about a whole 2 hours of use on it.
Whole system is cut just before the CAT, no holes or leaks
Asking $150 O.B.O
Stock KA24DE Fuel Pump
Was pulled when the Walbro went it, worked fine.
Best offer takes it
Stock KA24DE Rad with clutch fan and shroud
The rad worked fine befoe it was pulled out, has bent fins shown in picture but never leaked. Comes with shroud and clutch fan, or not… DOES NOT COME WITH RAD CAP
RAD IS SOLD!
Shroud and clutch fan still available
Best offer takes it
Stock SR20DET Redtop A/C Compressor, Lower Oil Pan, turbo elbow with O2 sensor, PS fluid container, and clutch slave cylinder
I kept my A/C compressor from the KA so I have no use for this one. The Lower Oil Pan has a dent in it, can be banged out. The turbo elbow is stock and comes with the O2 sensor still in it, whether or not it works is unknown as i never used it. The clutch slave cylinder could use a new dust boot over the pushrod and I do not know if it works as I never used it.
Best offer on any parts takes it
3" Stainless Steel Testpipe ( I believe Megan)
I got his testpipe off Toronto240sx but ended up changing my mind on the exhaust system. I got it for $50.
Asking $45 O.B.O
Bunch of misc parts/junk
Got a box full of misc parts/junk. Some items include Stock KA header heatshield, KA EGR, SR EGR, KA carbon canister, SR carbon canister, and one motor mount
Let me know if you need any of these parts, best offer takes any or all
Autometer Pro Shift Lite
This item came out of a friends 91 Eagle Talon. Was used for about 1 month, he then sold the car.
The items is in excellent working condition.
It is model number 5340 which is the standard shift lite with setting for 4,6,and 8 Cyl engines.
It comes with the stock 3.0 Pill and an additional 6.0, 6.4, 6.6, and 6.8 Pills
For those who do not know what the Pills are, they are little yellow tabs shown in pic below and the numbers represent what RPM the shift light comes on at, ie: 6.0 = 6000RPM, 6.4 = 6400RPM so on and so forth.
Asking price is $75 O.B.O.
Pic taken from JEGS website
HKS Super AFR
HKS Super AFR, came out of the same 91 Talon, in good and working condition aswell. Specs on the web say that this unit is better then some AFR/AFC out there because it has 11 mapping points rather then 8 and idle control.
Install instructions: http://www.zeroyon.com/index/content/view/27/47/
Asking $200 O.B.O
HKS Super AFR Pics:
Audio Parts
Dual 10" Sub Box
This is a big Dual 10" Sub Box Enclosure. In good shape, no rips, plexi-glass has a small crack from the end to one of the screw holes (barely noticable), and has speaker wires inside.
Asking $50 O.B.O.
12" MTX Thunder 6000 Sub
The sub was used and workd fine before i pulled it from my Neon. It pounds hard and loud to my ears but I am no audio expert.
This Sub was previously repaired before I baught it and the glue holding the centre cap on one side is starting to give. Can easily be fixed by an audio shop.
Asking $40 O.B.O.
10" Shaker sub
This sub is old but pounds hard in a HB. I am using one in my 93 HB and it is nice. The only issue with this sub is that the centre cap has some cracks that have developed over the years.
Asking $30 O.B.O.
Please do not hesitate to offer me a price on any of the items, i am not hard to deal with and am pretty reasonable. All items have a O.B.O. so do not think that my asking prices are firm at all.
I can be reached via PM or e-mail at filpereira@gmail.com let me know if you’re intrested in anything.
