-Megan Manifold, previously cracked on outlet, was welded back up. havn’t had a problem since.$100
-Megan dump pipe. double welded the welds to avoid cracking.$100
-nismo adjustable fpr$100
-nismo 740cc injectors( i think. they are the red ones, so thats why i say 740cc)$300
-GReddy Turbo Timer$130
-GReddy Boost/Temp warning guages, temp needs a sensor for either oil or water. can be used for either.$200
-Greddy sandwich plate. for oil temp/pressure sensors.$100
Super Advans
17x7
4x114.3
+35
all centrecaps included
wheels were used as drift spares. definately not mint, but they do get the job done. they have misc scuffs and scratched and a few lip bends. Central tire broke the centre of one of them where the centrecap threads on so you cant run a centrecap. easy to rethread i assume, but i didnt care cause they were drift whees. one wheel also had a stuck stud in it, and the previous owner used a die grinder to get it off, so there are some gouges but nothing shows when the centrecaps on.
looking for $350 without tires, or there are two 80% 215/45 GT champiro mounted for $500.
