89 8v 1.6 has cam and header ( motor has low comp is a smoker and an oil leaker)
93 8v 1.6 stock from an auto around 100k was a good runner and was going to replace the 1.6 currently in the zuk, but I am changing directions with it.
Wire harness and trans adaptor for 1.6 swap and pcm.
Samurai 5sp trans good shifter no noise and drive in all gears.
So basically every thing to do a 1.6 swap in a samurai except a fuel pump.
I would like to sell this as a package deal just to make this easier.
$800.00 OBO
Oh I will even throw in a Toyota 4AG supercharged corolla motor FOR FREE. It has a bad HG and no compression, I was going to retrofit the blower on to a suzuki motor 1.6 as it used the same belts and pulley sizes and the mounting set up would be fairly simple.
