Ok I’m was doing some fall cleaning and came across a bunch of parts that I’m probably not gonna be using. I may add more items as I come across them.
Item: A Pair Of S14 Rear Mud Flaps
Asking Price: $30obo
Condition: Used
Will Ship?: Yes at buyer’s expense
Contact Info: contact through pm
Description: I have two mud flaps for an S14. They’re in good condition, they’re not cracked or anything. They have a few light scratches, but then again they are mud flaps.
Passenger Side
Driver Side
Item: S14 Center Console
Asking Price: $45obo
Condition: Used
Description: Has a few light scratches but it’s generally in pretty good condition. The center console is a little dusty in the pictures.
Item: OEM S14 Steering Wheel
Asking Price: $200obo
Condition: Used
Description: I just installed a Nardi wheel on my S14 so i’m selling this one. The wheel is in good condition there’s one spot where the leather has come loose (see picture below) Air bag was never deployed.
Item: Black S14 LE Trunk with USDM Spoiler
Asking Price: $100obo
Condition: Used
Description: I have a Black Trunk lid from an S14. It comes with USDM spoiler, there are a few scratches here and there. (see pictures)
Item: Aftermarket (Unknown) S14 Fog Lights
Asking Price: $40obo
Condition: Used
Description: I have two Aftermarket S14 Fog Lights. The bulbs are blown, or at least one of them is for sure. They come with brackets that allow you to screw them to the bumper. They also include the harness that allows you to plug directly into where OEM S14 Fog Lights go.
This is how it looks mounted on a kouki
Item: Razo RA43 Aluminum Shift Knob (5spd)
Condition: Used
Description: I have a Razo RA43 Aluminum Shift knob. It’s used but it’s mint. It’s got a tiny scratch that you can barely notice. I had it on my S14 with sr so I’m assuming is the right thread pitch. The inside is a plastic piece that can be removed. The threads are a little stripped but because the threads are in hard plastic it still goes on the shifter fine. See pics.
Item: T25 from S13 Redtop SR
Condition: Used
Description: Stock T25 from S13 Redtop SR. There seems to be oil inside the turbo which leads me to believe that this will DEFINETLY need if not a rebuild, then it will need new seals. Odly enough when it was on my car it still worked fine. It would smoke only after idling for a long time, but it still held 7psi boost fine. I’ll get some better pics soon and check for play. Will come with wastegate.
Item: K&N Cone Air Filter
Condition: Used
Description: I’ve got a used K&N filter that was on my S13 Redtop SR. I’m selling cause I’ve upgraded to Greddy mushroom intake. The K&N filter was recently recharged/cleaned about 200km’s ago.
Item: S14 Kouki Sideskirts BLACK
Asking Price: $250firm
Condition: Used
Description: I’ve got a set of black S14 Kouki Side skirts off my 98 S14. They’re painted Black and come with the end caps. There in very good condition aside from the driverside having a light scratch/scuff. I’ll try and get some better pictures.
Some items to come, S14 LE front and rear sways, S14 USDM Brakes front and rear, USDM kouki grill, stock redtop valve train
Jon
