FS: Tomei Technical Trax Advance 2-way LSD *New $$$*
Tomei’s top of the line LSD. Beefier than the usual offerings from KAAZ etc. Brand new, in the box. Never installed. Comes with new bearings, gasket and diff fluid.
was $1500
now asking $1200
PM for details
Do you need output shafts to make it work?
Sorry I should add that it is for open diff. If you need an open diff I have an old one kicking around with axles and half a driveshaft $40 for the open diff and axles.
My open diff pumpkin and axles are sold. The tomei is still for sale.
i also have an open diff that someone can pick up… 20$
Lowered price
it will work with the vlsd diff casing.
Not sure if that was a question or a statement Seth. IFAIK it is designed to be dropped in the open diff. Either way it’s not a big deal since open diffs are all over the place for less than $50 if you don’t have one.
Open diff and VLSD use different bolts 12mm vs 14mm to attach the ring gear to teh diff carrier. So if this is for an open diff, it will accept 14mm bolt ring gears (or it could be the other way around). Either way it will fit in any R200 casing fine, but the ring gear that came out of the casing will only fit if it was a open diff ring gear.
-Martin.
I have the tomei diff in my S14, and didn’t need extra parts.
Its an awesome diff, and always remember to break it in properly!
New lower price, w00t for clearing out my storage unit!!!
