Hey guys, I’ve removed everything from my 1992 S13 240SX (4 lug) as I’ve decided to go with a big brake setup. Here’s what I have for sale…need this stuff gone:
HAWK HPS Brake Pads Front & Rear
-Only have 2 seasons of use (car was only driven in summer and was driven very little due to being worked on for the majority of that time). Pads are still in great condition, they have an abundance of material left on them, they look practically brand new. ZERO track days on these pads, never abused the brakes.
Price (both front & rear - will not separate): $60
FRONT & REAR BRAKE DISCS/ROTORS (Cross Drilled & Slotted)
-Only have 2 seasons of use (car was only driven in summer and was driven very little due to being worked on for the majority of that time). Rotors are still in great condition. As usual, the surface of the hub portion of the rotor has some oxidation, which happens with any rotor when they’re put through normal use. Never took the car to the track, never was hard on the brakes at all, just used them normally. Rotors are in very nice shape, no scoring, nothing is warped, everything is in good working order.
Front Rotors: $50
Rear Rotors: $45
For Both Front & Rear Rotors (Set of 4): $80
FRONT & REAR Brake Calipers (OEM)
-Not quite sure how many KM’s are on these, but they work great, no signs of leakage, worked great while they were on the car, always maintained a smooth feeling while braking. Still in great condition!
Front Pair: $50
Rear Pair: $50
Both Front & Rear Calipers (Set of 4): $90
S13 240SX Brake Master Cylinder
-Still works great, pedal always felt nice and stiff when applying brakes, provided good power. In great working order!
Price: $20
KONI Yellow Struts/Shock with Eibach Sportline Springs
-Not many km’s on this suspension, have never seen winter. Rides very nicely, lowest drop you can get with strut/spring combo. Smooth ride, not bumpy, good for a daily driver/occasional weekend track car. NONE of the struts are blown, springs are in great condition!
Price for all 4 with springs: $550 OBO, just shocks alone are worth over $800
