I have a 17 gallon gas air compressor. It is in used shape and works perfectly fine. There are only two things wrong with it. One of the plastic wheels are broken and can be easily replaced from one at princess auto. and the Psi reading gauge is broken and needs a new one. The compressor has a pressure regulator valve and that will go off once max psi is reached. The compressor is powered by a briggs and straton motor and is gangster. Comes with a new spare air line.
I am asking $150 for this compressor as I need it gone and no longer have space for it.
Call me at 647 204 8421 if you can’t wait for my pm response.
thanks
ken
