Has anyone here went through the process of converting 2 single car garage door openings into 1 double garage door?
I’m gonna be looking at a house with this setup, and want to know what to look for to be able to do this conversion potentially in the future if I go for this house. I know by removing the center column, the header will need to be either replaced or reinforced. The house is 2 story, but only half of the garage has a portion of the up stairs over it. Is this a job that could be done regardless, or could there be some limiting structural factors that could keep this job from happening that I should look for when viewing the place.
Secondly, I know a custom sized garage door will be needed. Wheres the best place to look for custom sized garage doors locally?
