gas guage not working
how can i check if its the pump that not responding or my wiring going from pump to dash?
its likely that its the wiring at the sending unit, it can corrode away and cause lose of signal by grounding out, if you swapped a fuel pump its likely you got the wires mixed up or they came loose
the pump came with the harness but its from a junk yard so who knows
