Ed1
                    November 14, 2005, 12:22pm
              1
              hi,
I’m looking for the part code for the SR turbo exhaust gasket that connects between the turbo exhaust and the 02 elbow pipe
does anyone here with SRs have the part code number?
I tried 14445 --> but nissan dealer can’t do with that number
is it possible to use high temp red gasket to seal it instead?
ty
ed
              ask for the gasket from a 300zx tt. It uses the same turbos
just make sure you get the gasket from the left turbo, it is identical to a sr turbo
 papapump:
Want me to post the Screen Shot of the FAST software which shows that BOTH Z32 turbo’s have a 4 bolt flange…  hence the gasket is not the same as the SR
As far as I can tell the only Z32 Gasket that will work is the Manifold - Turbo Gasket…
Ed… I will go throu the software again after dinner and try to hunt you down a part #
But the #14445  is the “part code” according to the EPC software…   I will phone my buddy @ Nissan tomorrow and speak with him if I cannot find a part # tonight
              here ya go bud
14445-75F10
Its for the S14/S15…  but should be the same
                Ed1
                    November 14, 2005,  2:26pm
              6
              thanks a bunch jedi!
btw.  the 300zx tt is 4 bolt…  I have one of the turbos at home
thanks again
                system
                    November 14, 2005,  2:48pm
              7
              I beleve you can also get the 5 bolt gasket tho, I think I orderd one from Nissan.
poopy memory
              Right from Heavy Throttle…  and they say their is a Z32 4 or 5 bolt Gasket…  Why I could not find that in the Nissan EPC software is beyond me…
SR20DET Parts from US Car Part Source
Exhaust Manifold Gasket - 91 B13 Sentra SE-R with 2 liter SR20DE
4 Hole Turbo Manifold gasket - Z32 300ZX TT T25 gaskets
5 Hole Turbo Extension Gasket - Z32 300ZX TT T25 gaskets
O2 sensor, slim one - Nissan Part Number  22690-19P20
370cc Fuel Injectors - Z32 300ZX TT (purple plugs)
MAF - 89-90 SOHC 240SX, Stanza, Truck w/2.4 liter
Fuel Injector O-Rings - Z32 TT, DOHC 240SX
Timing Chain Kit - 91 B13 Sentra SE-R with 2 liter SR20DE
Belts - (PS, AC, alt) - Gates K050370 Alt.   K040345 PS & most AC
Spark Plugs -  91 B13 Sentra SE-R
S14 SR Oil Filter -  95 B14 Sentra SE-R
S13 SR Oil Filter - 91 B13 Sentra SE-R
                Ed1
                    November 15, 2005,  3:25pm
              9
              my nissan dealer said the gasket is on back order…
anyone know where I can get it quick/faster?
                Ed1
                    November 16, 2005,  1:23pm
              10
              well,…  nissan says the gasket will be here on nov 22…
should I wait?  or just use copper liquid gasket?
only 6 days…  so it depends on if you are in a hurry or if you must have the car on the road within 6 days.
many people use the liquid gasket thou…  it just comes down to your preference i suppose.
