What are good heads for a 350? I have heard some people say vortec are the way to go, some tell me AFR. I know AFR heads are awsome on stangs, but to my understanding they do not perform quite as well with GM, or so I have heard. Is this true?
Vortec can be good on a budget. You might be thinking of trickflows, which have a good stang reputation, but have good GM heads as well. AFRs make great power on everything and are one of the best street heads you can get.
AFR FTW but there up there in price
What about stock heads ported out? Lloyd Elliot and Advanced Induction both have very good reputations for their headwork.
well im not real sneaky so idc who knows. As you knwo I got an 84 trans am now with a 305 ho. I got a 350 for it and want to do heads, cam, intake, exhast. my goal is to be 12s on motor. this will be a bit of building and is not going to be done over the winter mind you, but I want to do my research and do it right. Im not in a massive hurry. As far as a budget goes, i dont wanna throw in more than sat $4k. especially since it is money I do not yet have, hence a gradual build. I just wanna know realisticly what I am lookin at getting myself into as far as setting this goal.
Are you rebuilding the whole motor? Or just heads and cam?
There are so many Chevy heads out there it’s hard to know where to start. The two things that have to be specified are budget and goals/purpose of the swap. There is a big market in used heads, you can save a ton of money going that way. The more exotic choices can make huge power, but be very expensive. Stuff like the SB 2.2 is what I mean by “exotic”. As far as factory heads, the “Fast Burn” are a great choice for out of the box performance.
Per GM’s promo literature:
The biggest news to come from GM Performance Parts in recent history is the all new Fast Burn cylinder head for small-block Chevy engines. This head incorporates more technology, features and performance potential than any previously designed GM 23° head. We have completed the development and the validation of the head and are in the process now of building the production tooling. A small number of these heads will be built from prototype tooling, these heads will be used on the Limited Edition ZZ430 Crate Engine.
Some of the details about the Fast Burn head are as follows, and I'm sure that once you've read this you'll be as exited about this new head as we are!
The all new 23° Fast Burn small-block cylinder head has the highest performance potential of any 23° small-block head ever developed by General Motors. With over twelve months of development in design, flow testing, dyno testing and race track testing, the Fast Burn head successfully brings together a number of new technologies. The subtle integration of all aspects of the head design allow the Fast Burn head to make tremendous power on a variety of engines from 350 to over 400 cubic inches.
The name Fast Burn refers to the head’s ability to quickly and completely burn the air/ fuel mixture, making higher cylinder pressures and therefore more power. The shape of the combustion chamber has been carefully and painstakingly designed to accomplish this Fast Burn with flat top pistons. Therefore, flat top pistons are recommended with this cylinder head. Further, it is not recommended that the combustion chamber be modified or re-shaped, as this is very likely to decrease the efficiency of the chamber.
The Fast Burn head is designed with a .400 deck, which provides the necessary structure for the head. This revolutionary approach to head design allows a great deal of material to be removed from other portions of the head, allowing for considerably larger ports and water jacketing. The substantial deck also provides unsurpassed clamping force for cylinder head gasket retention. The super rigid .400 deck thickness can be machined down to .340 safely for all-out performance applications and higher compression. Milling beyond .080 may increase the possibility of structural failure in long tem use in extreme performance applications, leading to possible head gasket seepage and other problems. Other ways to adjust compression ratio with the Fast Burn head include top of piston design and piston installed height.
Unlike the GM Performance Parts Bow Tie heads, and most aftermarket performance heads, the Fast Burn head requires no additional porting for maximum performance. In the past, the industry has added material to heads to allow substantial porting. The downside to this is minimized water jacketing, poor out-of-the-box performance and significant additional cost to performance enthusiasts. The Fast Burn head utilizes GM Performance Parts' Cast-Ported technology. Cast-Ported simply means that throughout or developmental process as incremental improvements in flow, combustion and cylinder fill were identified, those improvements were incorporated in the casting and machining tooling. The end result is a cylinder head that achieves maximum performance out-of-the-box. While additional porting of the Fast Burn head is not recommended, light sanding to remove minor casting imperfections and polishing of combustion chambers and exhaust ports is acceptable.
All Fast Burn heads are CNC machined to exacting tolerances, thus eliminating the need for blue printing of machined tolerances. The result of this is cost savings to performance enthusiasts and unsurpassed out-of-the-box performance.
The Fast Burn head has taller than typical rocker cover rails, providing exceptional clearance for rocker arms and valve train supports typically used in all out performance applications. Additionally, the tall rocker cover rails reduce oil loss at the valve cover gasket by placing the gasket higher, out of most of the standing oil that occurs at high RPM applications.
The rocker rails are CNC machined for superior rocker cover gasket sealing. Front head faces are drilled and tapped for typical accessory drive bracketry.
Provisions are drilled and tapped for plug wire retainers above the exhaust port faces.
The Fast Burn head accepts both center bolt and early style four bolt flange mount valve covers. No valve cover adapters are required.
Cast-Porting allows for larger water jackets for superior cooling.
Signature etched with GM Performance Parts logo.
Intake manifold mating surfaces are drilled and tapped for both Vortec and conventional raised port style manifolds.
D shaped 78cc exhaust port and runners provide exceptional flow for applications well in excess of 500 horsepower.
Raised runner (.240 higher than conventional 23° head) intake ports with 210cc ports and runners provide exceptional flow for applications well in excess of 500 horsepower. Raising the top of the intake ports provides a better “line-of-sight” through the port and onto the back side of the intake valves.
The 62cc fast burn combustion chambers are the most efficient combustion chambers ever to be incorporated on a GM Performance Parts cylinder head. Their Fast Burn efficiency produces higher cylinder pressures by burning more of the available fuel before the piston starts its power stroke downward. Additionally, by more completely using the available fuel, the head ensures that an engine is producing more power for a given quantity of fuel.
The Fast Burn head’s specially designed valve seats will accommodate up to 2.02 intake valves and 1.600 exhaust valves. Their design also provides superior structural characteristics.
The 2.00 hollow stem lightweight intake valves are utilized to provide exceptional flow and intake charge velocity. Their light weight makes them suitable for sustained high RPM applications as well as reducing loads on valve springs, rocker arms, push rods, roller lifters and camshaft.
The 1.56” sodium filled lightweight exhaust valves have all the same great benefits of the hollow stem intake valves. In addition, they are able to perform in extremely high-temperature performance applications.
Light weight valve spring retainers combined with light weight valves helps ensure long-term high RPM durability.
Screw-in 3/8” rocker studs are used., and accept most available self aligning style roller rocker arms.
Uses all conventional low cost readily available 23° self aligning rocker arms and valvetrain supports and hardware.
GM Performance Parts attention to detail in the Fast Burn head tooling assures super clean and accurate castings.
This cylinder head is a bolt-on 40 horsepower increase when used on our ZZ4 crate engine. With appropriate camshaft selection, a single plane intake manifold and a 750 cfm carburetor, a ZZ4 crate engine is capable of producing 500+ horsepower.
When tested on a 383 cubic inch small-block engine with 9.8 to 1 compression ratio and .540 lift roller cam, single plane intake manifold and 750 cfm Holley carburetor, the Fast Burn heads produced 497 horsepower at an incredibly low 5800 RPM.
Total ignition timing to be used on a Fast Burn head engine will vary based on a number of factors. However in our extensive dyno testing most configurations made the most power with 34° of total timing.
A pair of prototype Fast Burn heads successfully completed the 1998 Sebring twelve hour race with no signs of fatigue or problems of any nature. In fact, when run on a dyno after the race the engine produced ten more horsepower than it did after initial assembly and break-in.
A complete pair are $1,400 ready to bolt on. They are designed to work with flat-top pistons.
Step 1. Finish paying me for the car.
Step 2. Stop wasting time on here asking about shit you are not going to buy and get a job so you can pay me for the car.
lol. nomatter what u try to spend, it will always end up being more, usually thousands more. so yeah, prolly pay for the car first… …
We met Ron from AI (I think it was Ron, I suck at names). Very nice guy and he knew his shit, I would trust a set of his heads.
12s is easy, if you do any kind of heads/cam with exhuast, you can get there. Pay off the car and then come talk to all of us at mighty about what you are tryin to do with the car.
ahahahahahahahahahhahahahahahahahahahahhahahahahahaha
…ahahahahahahahahahahha.
he forgot to tell everyone its a 350 from a dump truck with ONLY 26000 miles. Im guessing those 26000 miles are all highway abuse free miles too. :bloated:
12’s is quite easy with no matter what aftermarket heads you get.There are loads of people in the 12’s with vortec heads,double hump’s and even some 1973 stock Iron Heads have me into the high 12’s.
AFR makes great heads but if 12’s are your goal then you can save yourself quite a bit more and go with something less costly.
where the motor came from actually doesn’t matter in this case because he is throwing monopoly money at it…
but really… if he is doing heads/cam then the fact that it came from a truck doesn’t matter.
i know that, but i was pointing out to the fact that he still hasnt told us if he was going to rebuild it. A good rebuild should be the first thing on his list, not heads and cam and other upgrades, but like you said, monopoly money.
:word:
Jack, Paying you the rest is #1 on my priority list. I am planning on moding the car. That is why I baught it. So why you say I never will :gotme:.
The truck is an (I believe) 85 chevy 3500, the frame broke. So my old man is selling me the engine for $400.
The engine has like 35k on it. of those miles it prolly has 10-12k hard miles, as my dad used the truck for his daily driver also. The engine is like 3-4 years old.
