So my right headlight is out on the low beam, but the highbeam works, left headlight perfect, i changed in 3 different lights on the right side and they all do the same thing, so it is a wiring problem, anyone had this or know how to fix it?
Yeah, Ive got that too, except vice versa. Low beam works, not high beam…
i wish mine was like that, i dont need my highbeams!!!
90% chance it’s just a ground issue. I used to work in a automotive electrical shop, and bad grounds accounted for SO MANY of the problems we would see!
I would check the grounds for your headlights, and while your at it, make sure all your lights have good grounds as well as your battery and main frame/engine grounds. Allways a good thing to make sure is clean and tight!
I put my side marker light back in on the right side and then 2 days later the headlight comes on, and it hasnt gone out yet… could the missing side marker lights cause some sort of unbalance in the other lights? Just a shot in the dark.
