Somewhere has to have them… need them to modify the color of my HVAC controls so that they are not the only green thing in my dash.
try KS. that’s all you need to do to change the HVAC? you sure? i want to do it too!
can get them at autozone ,but wouldnt recommened them ,had them for the lights inside my old truck and it eventually burns right through the red . better off wiring up some leds in my opinon but who the hell am i …
looks like it - read on nasioc how to do it, looks super simple :tup:
its on a 02 or 03 wrx it looks like but still should be similar for hvac controls
knew that was coming at some point
Red condoms?
They really do have them in the section…
ive got red condoms on my gauge lights
if they are the same bulb as in the autometer lights, you can buy actual led bulbs for the same socket. i have blue ones right from autometer. worked great.
http://superbrightleds.com/mini-wedge.html
specifically:
http://superbrightleds.com/specs/74_t15.htm
oh hah, ok :tup:
i’m a bit bigger than those, dunno about you man !
I actually want to do this for the amber HVAC lights in my car too, i saw an eclipse with blue LEDs installed, i’ve taken apart my panel before, and it looks like theres enough space to cut the old LEDs and solder a new one in. Idk if thats the case with the STI, but it would be pretty easy, and you wouldnt have to worry about the condoms burning through and having to replace them.
if they have LED replacements i’ll def put those in, if not, whatever getting to my HVAC to replace them is cake
bump pep boys ricer section doesn’t have anything close to small enough for this… anyone have any other ideas?
