i know this is probably not where i should post this but i need help with installing LEDs to my speedometer ect gauge. I cant find anywhere that would solder them.
anywhere in buffalo?
thanks ahead of time
moved to gen auto
Solder them yourself? Soldering is soooooo easy.
^ +1
You can pick up a little soldering kit for cheap. Practice on a few things first.
EDIT: Are you sure you want to solder to your cluster??? Try - www.autolumination.com and see if they have a replacement for your cluster.
