I plan on getting HID’s for the integra. I’ve deciced just to go with a plug and play setup for the time being. If I feel the need to retrofit, then I will do it then, but I’ll try the plug and play setup first, simply because its cheaper and not a PITA.
So, onto the real question. What brands should I be looking into? What kind do you have? What are the -/+ of that brand?
If you have some pictures of your setup, that would be great. Also state if you retrofitted, or just used plug and play.
remember you cant just buy HID lights you need the control module for them so that they actually work, IF they are real HID xenon lights. Back in the day people use to just rip them out of maximas and call it a day. Real HID setups are expensive. but good luck
<—HID noob
what intensity HID bulbs give off what colors? I’ve seen bright white, yellow(amber), blueish and purple looking lights
what are some decent brands that arent too expensive but dont suck?
any info would be appreciated (im looking to go the plug and play route, no retrofitting for me)
If you’re just retrofitting, i’d go with Xenondepot, if you want to go all out buy Hella’s from RallyLights.com but that WILL get expensive. In terms of light output, I wouldnt stray outside of 4000-6000k. I’m running 5300k high and lows on the 951.
