honda b series transmission question
Im looking for replacement sliders but not sure the name that the dealers would use? http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=INTEGRA&catcgry2=1997&catcgry3=3DR+TYPE-R&catcgry4=KA5MT&catcgry5=MT%2BMAINSHAFT&ListAll=All&vinsrch=no
Story behind this:
Getting my tranny rebuilt and I need 1-2, 3-4 sliders. The tranny guy needed an exact transmission code to get a part number. Since the tranny has no markings I’m trying to cross reference part numbers to check if they are the same or not. Thanks.
additional info if needed:
hydro tranny
It’s a factory lsd tranny. Previous owner thought it was a gsr, I believe its a ITR (counted gear ratios, b16 and ITR have same ratios but because the lsd I’m leaning toward ITR.)
You well have to count teeth on all the gears to figure out exactly what’s in there. And as far as"sliders" the well come in the gear set you buy. Let’s say you replace countershaft gear 3. It would typically come with the gear, synchro for both gears 3 and 4. And the hub and hub sleeve that engages both gears 3and 4.
Edit: you should have brought your trans to me, I rebuild these in my sleep :wink:
I’m just here to say Andy knows his shit.
Thanks man. Next time I will haha. I just took it more local. I live in Olean
