I will keep updating this thread rather then starting a new one.
If you are looking for something particular lmk. I may have it somewhere. I have tons and tons of random dash pieces and interior trim!
Engine parts
D16a6 long block, spun bearing, still runs $75
JDM D15b vtec short block, spun rod bearing, $30
B18a complete intake manifold $50
D-series starters $20 each, I have 6
D-series light weight flywheel $80
stock OBD-1 injectors $20 set
D16Z6 AT intake mani, no tps $20
skunk2 D16 adjustable timing gear, slight damage on ring $30
d-series axels $20 each, have 2 sets ef & eg
92-95 d-series shift linkage $20
D16Y5 vtec head, no solinoid $25
ECU’s
PM6 $50
P09 $30
P06 $30
Integra 94’ up
Black door panels $40 both
black center console w/ arm rest $50
94-97 tails $40
Gauge cluster MT w/ plugs $60
tan console w/ arm rest $30
tan floormats f&r $20
tan rear cargo cover $30
climate control $20
M3 style mirrors with blinkers $25
CRX
Si passanger “CRX” door panel $20
black rear cargo compartment $20
black center console $15
radio bezel $10
e-brake console $5
90-91 black corner lights DOT SAE approved $20
CRX SI wheels 14" with center caps $100 all
oem struts/springs rear lca’s $50 set
EG Civic
2dr or HB white driver fender $30
New still packaged oem 2dr or HB front bumper, primed $60 (SOLD TO NISKYSPY)
Any motor mount $5 each
under hood fuse block $10
EF civic
Si console $20
drivers side fender HB $20
black door speaker covers $20 both
Black vents $20 both
Prelude front seats, black, great shape $40
Custom fiberglass 3 gauge pod, replaces center vent 2" gauges $50
Custom fiberglass PS2 glovebox, needs painting $50
90-91 cluster no tach $30
headlight brackets 88-89 $20
MT pedal assembly $15
clutch cable $10
Turbo misc
probe gt intercooler $25
IHI RHB5 turbo, minimal shaft play $100
Funtion7 oil restrictor, brand new $20
voodoo 6 port vacuum manifold $20
HKS SSQV mounting pipe $10
DSM bov $15
MAP bypass valve ,new $10
Willing to trade for CRX SIR parts (yeah it;s a long shot ::)).
