Hot Water Tank Hook Up
yea, tankless is still a bit in the early stages… We considered one, with the rebates & incentives it’d be about the same as a tank. But the exhaust piping is ridic, its like $100/ft or somthing.
Bradford White 40 gallon Hwt 289.00 1 yr parts/labor 6 year warranty on leakage. In stock at Jordan Supply on Military Rd.
That is what I just bought. Actually bought it in December and have been way to lazy to put it in. Plan on doing it soon though.
how much?? ok 289.00 see that whats the EF…that one is only a .58%
ok they will not sell it to me i just called…he said he can only sell to a contractor…NEXT
up… need one asap bank OKed the move in so now all i need it this…someone asap
kthanx bye kisses
sorry. brb
your right i should have just pmed you
Gas? Standard vent?
.61 or better:
40g $489.99 - 12yr tank / 12yr parts - 1st hr rate: 81 / recovery:41 - .63 e factor
50g $549.99 - 12 yr / 12yr - 1st hr: 97 / rec 41 - .63 e
Powervented models are more $ ($719 - 739) and have less warranty (8yr / 2yr) but higher e(0.65).
jordan supply cant sell to reg people
thats cheepest?
nope. There are other models, but they are 0.60 or less.
YGPM
Thanks Nick, but I’ll be in this house for maybe 3 more years. I’m lookin for the cheapest.
Cheapies:
30g $299.99 - 6yr / 6yr - 1st hr 66 / rec 36 - e0.61
40g $299.99 - 6yr / 6yr - 1st hr 70 / rec 36 - e0.59
50g $359.99 - 6yr / 6yr - 1st hr 73 / rec 35 - e0.58
Sho 'nuff. Just called them. Contractors only.
just chiming in on the tankless water heaters…
My grandma just put one in at her house (2 full baths/dishwasher) and have never had a problem with it. And as for it not getting hot- it’s constantly set to 130*F and it will burn the sh|t out of you, and the same holds true when you do laundry, dishes, at the same time.
But, she did spend 2700$ for the unit installed.A little bit of a difference but as already said between the tax credits, and her gas bill being cut in half, even in the winter, it’s almost already paid for itself after about 8 months.
The initial investment is huge though.
And will you be installing it yourself (i’m looking for someone to install a gas fireplace)
yes tankless is good if you spend the money.if you go with the $800 ones they dont work but if you get the $2000 ones they work… i should be putting one in in the next 5 years or so but right now i have nothing and need something… once the $$ is there i will be doing it
yes i will put it in my self… i have also put in a ventless gas fireplace and its reall easy… running the lines were a lot easer then i thought it would be…I will not do that type of work to anyones house do to the fact i dont have INS. for it… and i dont want that on my back… same goes for working on cars i know you did not ask but same deal
Ooh. Vent style?
3"
:shrug:
BTW - the 12yr units are “self cleaning” fwiw.
