I’m thinking about selling my car for something else, but I need to figure out how much it is worth at the moment. The specs are:
Car:
2003 Nissan Sentra Spec V
~54000 KM (90% highway)
Never raced, only hit redline 3 time
Fully loaded (i.e. ABS, sunroof)
I removed the rear sub unfortunately in the sound system
Mods:
Faktion Short shifter
16x7" Rota Slipstreams (Spoon wheel replicas)
Nismo R-tune header
Apexi WS2 exhaust
Koni Yellows/GC coilover sleeves
Steel cluch/brake lines
UR Pulley
Motor Mount Inserts
Oil Filter/Oil has been changed ever 6000km with Mobil 1 synthetic. Rebuilt steering rack has just been installed as the old one leaked.
The Bad:
- The front bumper has some dings in it an pretty big rock chips so it probably needs a repaint.
 - Hood also has chips in it and will require some touch up.
 - Exhaust bangs on rear beam. You’ll need to get about 1" removed from it to prevent this (or so I’ve read on the Sentra forums)
 - Current suspension is great for handling, but clunks during low speed turns due to the slight twisting of one of the GC sleeves. Unfortunately I don’t have any ideas as to how to fix this at the moment. I bought this suspension set up used a while back, but I’m not sure what the original owner has done to try to fix this problem.
Thanks for any insite. Sorry about the long post.
