i can get these made but if i want to avoid set up and tooling costs i need to buy 25 pairs…
not likely that i can do this on my own.
i am not sure what type of studs to accompany with these spacers but perhaps you folks would be interested in the hub centric discs without the studs and we cna figure out what studs we want to use later.
i know i can get ARP studs, but they will cost about $40 for 10, iono if that is good or not.
$100 for pair of spacers (no studs)
the ones that i have there are H&R 15mm but i am sure we can get other widths.
it would be best to make them all the same i think
aftermarket studs come in 55 and 60mm typically
so at 10mm the 55mm stud would give you 5mm more thread engagement than stock. or you could use a 50mm for equal thread engagement.
15mm spacers would be mated well with a 55mm stud and 20mm would be best with a 60mm stud.
no point in me doing 25mm spacers, the H&R’s come with studs pressed in for them so that is prolly a better bet.
