hyper flex installation s13
I just ordered the hyper flex master bushing set, does anyone know aproximatly how much a shop will charge to replace every part (Toronto to Hamilton area). Thx
Includes:
  • Front Control Arm Bushings
  • Front Strut Rod Bushings
  • Rack and Pinion Bushings
  • Front Sway Bushings 24 and 25mm
  • Front End Link Bushings
  • Rear Sway Bar End Link Bushings
  • Rear Subframe Inserts
  • Rear Suspension Arm Bushings
lol it wont be cheap
a few of those bushing require a hydraulic press, as well the originals in some cases need to be burned out. thus nasty fumes and airorne chemicals.
you’re prolly looking about 200 - 500 depending on where you go, or at least a days worth of work at abour 70 - 110 an hour…
expect soem hardware to be replaced, ie:nuts/bolts.
some of these bolts are in the $10 range (nissan price) so I’d have an extra $100 for this ish.
Damn it… well thanks for your responses. :cry:
The camber bolts are about $17each ($11 washer, $2 nut, $4 bolt) I believe.
Most bushings will come out with a press. The rear lower arm I believe
you have to grind down a very thin lip on the bushing, and then use a press.
As for burning bushings out, up to you, but I wouldn’t do it myself. You
still have to remove the steel collar once you burn the bushing out.
How much were you expecting it to cost?
Have you ever removed arms and replaced bushings?
It’s no easy task.
And to replace all of those components, $500 is a bargain from a shop.
Best bet is to do what I do. Remove the arms, then have a shop press out the old, and in the new. That way you make their life alot easier and it is much cheaper.
Ya thats what ive decided to do.
