Pants
June 27, 2008, 5:59pm
1
i need nissan part numbers for the following …
Manifold to turbo gasket
Turbo to O2 pipe gasket
SR t25 turbo locking plate
Sr20 3 layer metal exhaust manifold gasket
Compressor 2 bolt inlet gasket for SR20DET with factory T25/T28 turbos
3 Bolt compressor outlet gasket for T25/T28 SR20DET
manifold to turbo studs
manifold to turbo nuts
thanks …
Jowo72
June 27, 2008, 6:10pm
2
Turbo to Mani gasket #14415-17M00 -SR
Jowo72
June 27, 2008, 6:14pm
3
Turbo outlet flange gasket
14445-26E00 (S13 all)
14064-7B000 Studs for O2 Sensor Housing
Jowo72
June 27, 2008, 6:22pm
4
I’m pretty sure that “most” the parts you seek can be sourced from a Z32 TT.
Pants
June 27, 2008, 11:53pm
6
at cost it shouldnt be to bad
we will see
sil8t
June 28, 2008, 5:52am
7
i have the felpro part number for the turbo gaskets at my house. ill get them for you sometime tonight
DJPyro
June 28, 2008, 5:05pm
8
The turbo elbow studs are M8x1.25, mine kept coming out, so I replaced them with some Grade 8 hardware and lock washers. They’re holding like a champ. Can’t remember exactly what length I got, but I just picked them up at CT for dirt cheap.
The studs are also available from Toyota, I could look up the part number if you’d like.
Check this thread out for like every part number ever:
http://forums.freshalloy.com/showthread.php?t=178325&page=5
Stud part numbers and turbo gasket info is on that page and one or two previous.
