i’m looking for an ignition box. I’m leaning towards a MSD Digital6.
What is your favorite, and why? MSD, Mallory, Crane, ACCEL
any bad experiences? i’ve read that a 6A box, and MSD coil will literally burn through a standard cap/rotor.
i had the MSD 6al Box & coil on my truck and no issues at all for the 2 years it was on…
I had the MSD 6 box as well without any issues for 2 years. I read differently on forums; lots of problems with them.
ive had a digital 6 for a while too… never any problems with it.
I have the old standby MSD 6AL box on my Z and it seems to be trouble free…old technology though…still analog, not even digital…
115mj output
I had the Mallory HyFire VI on my Duster…It is Digital and you get a lot of nice features for the $$$$. Two rev limiters, a start retard, a high speed retard, a boost-referenced retard, and an RPM window switch all built in.
135mj output
I have heard a lot of good things about the Pertronix Second-Strike box. It digitally supplies a second spark pulse throughout the entire RPM range after a user-adjustable delay offset. This is said to increase low end torque noticably. It has a single rev-limiter.
250mj output
If it’s high output you are looking for, then the Crane HI-6 is the winner. It outperforms all the other boxes on the market as far as high spark output. It has a single rev-limiter.
1,200mj output
Still confused, yeah, me too…I guess if I was buying a new one, I would probably go for the Crane…The more spark the better for Nitrous!!
i don’t know if MSD got better or not. i had a spell where couldn’t get a new good working box for a while. this has been a few years now. i am still partial to msd since i know how to make it work.
135mj output
I got the Mallory 685… HyFire VI i believe. NICE setup. Great for my nitrous motor. Has all those above features. Works great
still using my factory distributor with a aftermarket coil forget what it is and new ignition module and had no problems this year
CRANE>
whats the big difference between stock spark and aftermarket ignition boxes? can it really make that much of a difference? Im sure it can make a difference on V8’s but but big of a hp increase / better spark are you talkin?
I had a digital 6 box on my car and it took a shit the first time i drove it on the street. Summit gave me a new one, never had any problems after. The only bad thing with the digital boxes is that you cant jump start the car with another car or put a battery charger on and start it or you will fry the box.
didnt know that. I’ll have to avoid doing that. My mallory has a bypass connector option that you plug in to go back to stock ignition. I wonder i could just do that real quick if i ever need a jump or need to jump someone
are you sure. i have done this dozens of times with my digital 6 box and it lasted 4 years so far.
Does Dynatek offer anything for the v8 crowd?
Yes I am sure check this out. http://www.msdignition.com/forum/showthread.php?t=13023
mallory HyFire VI , great for the blower application had it for 6 years now no issues. unilight distrb.
