Is there an easy way?
I would rather not cut/paste into individual csv files as it takes forever just to highlight the data? ( only 500,000 rows)
I do not know VB, but i’ll bet it would be easy to write a macro to import them?
Any thoughts?
Any thoughts?
upgrade to 2007
I thought you knew about the corporate life.
short answer: No.
You can however, bring in a 500k row CSV to Access.
Access not found.
get them to buy you 07
no other real options
I’m, in the 300k’s and 10 sheets now…
I’ll post the macro if it works and does not crash when done.
516621 rows successfully imported into one excel file with 11 sheets.![]()
I had to make a few changes to some code I found online, and I had to create a schema.ini file.
Sub ImportLargeFileADO()
'Imports text file into Excel workbook using ADO.
'If the number of records exceeds 65536 then it splits it over more than one sheet.
'danielklann.comDim strFilePath As String, strFilename As String, strFullPath As String Dim lngCounter As Long Dim oConn As Object, oRS As Object, oFSObj As Object 'Get a text file name strFullPath = Application.GetOpenFilename("Text Files (*.csv),*.csv", , "Please select csv file...") If strFullPath = "False" Then Exit Sub 'User pressed Cancel on the open file dialog 'This gives us a full path name e.g. C: emp\folder\file.txt 'We need to split this into path and file name Set oFSObj = CreateObject("SCRIPTING.FILESYSTEMOBJECT") strFilePath = oFSObj.GetFile(strFullPath).ParentFolder.Path strFilename = oFSObj.GetFile(strFullPath).Name 'Open an ADO connection to the folder specified Set oConn = CreateObject("ADODB.CONNECTION") oConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & _ "Data Source=" & strFilePath & ";" & _ "Extended Properties=""text;HDR=Yes;FMT=Delimited(,)""" Set oRS = CreateObject("ADODB.RECORDSET") 'Now actually open the text file and import into Excel oRS.Open "SELECT * FROM " & strFilename, oConn, 3, 1, 1 While Not oRS.EOF Sheets.Add ActiveSheet.Range("A1").CopyFromRecordset oRS, 65536 Wend oRS.Close oConn.CloseEnd Sub
schema.ini
[data.csv]
ColNameHeader=True
Format=CSVDelimited
MaxScanRows=25
CharacterSet=ANSI
you’re not saving as a CSV are you? CSV’s require seperate files for each sheet.
nope.
I had a data logger that generates my .csv files.
But, it makes huge files. I need to analyze the data in excel.
The problem I had was getting from .csv to xls.
