-2 white rocker panels(drivers side and passenger) … In good condition.
-1 white passenger front fender
-1 rear drivers side quarter panel. If possible.
-Rear mud flap pastic things. W/e they called. In white!
Lemme know if you have these in white, or the rockers primered or anything. Thanks alot!
Standard auto wreckers, I think i spotted a red pignose there. should be good for some of your stuff, I also need a passenger headlight assembly, but that perticular one has been hit on that corner :(. good luck
u should just get new rocker panels if urs are rusted…IMO the rear mudflaps on 240’s dont look good. It looks cleaner without them…whats wrong with ur rear quarter panel just curious. If its rusty or w.e u could just get a good auto body shop to replace it with just normal metal
you have to cut the rockers off then weld them on, then a thin layer of bondo to hide and imperfection in the weld, and to make the body straight…then you would have to paint them…
edit
and if u get a new quarter panel it will have to be cut/welded on, and ur going to have to paint it…either way u need to paint
