What else would i need and how much work you think i,m in for?
http://www.clubgp.com/newforum/tm.asp?m=1322310&p=1&tmode=1&smode=1
pewter can put the intercooler under the supercharger for you im sure. youll have to get a water pump like the one the typhoon has(campers choice $62) youll need a heat exchanger like a trans cooler mounted up front. hose and elbows to route it all together. you could run the overflow into the factory rad overflow.was this tested for clearance under hood? and also do those lines come out near the crossover pipe?
hood clearance should be good,he ran it for 300 miles and worked with zoomer from zzp,lines do go over x over i think,thats the only way i see em going? And as far as the fabrication on pipes water pump and lines i would need help with that due to no nohow and tools. I would love to get it though:D Fuel rails need to be fabricated too…anyone? I just don,t knoe if it would be worth it?
fuel rails maybe tough??? once its installed you install the cooler/ exchanger then plum the system. water pump is small and can mount near the d-side fender.
Shoulda stuck with a T-bird sc, comes with the intercooler. hehe:D
Wait a sec…that just looks like a heater core
he wants to make hp ford intercooled =210 gm non = 240+
hey at least its not a family sedan!
go to work . its almost 2:00:embarass:
not till 3,jay told me you stopped down shoulda just had him change the oil
thanks next time. but i need antifreeze flush.
next time and it will be done as of now i am gaining more interest in this:D
