he all, need the torque specs on the head bolts for a ka.
i know its somthing like
10
16
23
loosen
16
23
42
60
just cant rember… thanks
10
16
23
loosen
16
23
42
60
In numerical order, torque the bolts down to 20 ft/lbs then again to 59ft/lbs.
In order loosen all the bolts.
Then again torque the bolts down to 25ft/lbs in order than 60ft/lbs.
All of these values are using ARP moly lube. Spec will be different for Oil and grease but moly-lube is recomended.
took me about 30 seconds on google… i cant sleep and got nothin else to do so enjoy.
hope this helps!
Curiously why do you have to tighten in numercial order does it matter ?
yeah thanks man thats awsome
it matters because the head gasket will actualy change shape and you want it to flex out not in to a bubble… its hard to explane…
you can try it non-numerically and see what happens:) if the gasket isn`t snug in a proper way it will blow out te side and well your in trouble then
nahhh then you just do it again!!! its tonns of funn
edit doing it the first time lol
Changing it in the car is a PITA… Not undoable though, I did it in a night… Is that the new coupe Shawn?
no thats my old hatchie
just saying it was a bitch, id had never dont it before so it was all learning for me
but now that i know all the little tricks and shit i can change one in a weekend, why pete would you like to help??
i wont do my homwork while you work on the car if that helps lol
Sure, come pick me up, I’ll give you a hand
… Hell, you come pick me up to do it tonight and I’ll do it all myself. You can sit there and drink beer the whole time.
suuureeeee ill get right on that. ill leave now, see you tomorow night haha
