Kicker 10" S10L7 Solobaric subwoofer
Orion Xtreme 300 amplifier
sealed box
grill
The dual voice coil subwoofer is wired in series to run at 4ohms. The amp can be bridged mono. Was used for its high sound quality and performance with low weight. This same model sub new still retails for $280, the amp for $300. I purchased these new from Kustom Works if my memory is correct.
$250
text or call 716-7two5-5366
From the interwebs:
Get good quality and loud sound with 1200 watt peak power handling in the Solo-Baric L7 S10L7 (2002) car speaker. This Kicker car subwoofer has a frequency response of 24 Hz - 100 Hz for deeper bass, and better mid-range output. The 85.7 dB sensitivity of this Kicker 10-inch speaker delivers clearer audio even at higher volume. The Solo-Baric L7 S10L7 (2002) speaker with 4-ohm (dual coil) impedance delivers great sound output. This powerful and versatile Kicker 10-inch speaker delivers an impeccable acoustic bass reproduction. This Kicker car subwoofer is made from metal material that makes it very sturdy.
