Ill start with saying this is on a 94 Honda Civic CX. I bought 2 sets of ARP wheel studs. Not knowing at the time that the whole hub/knuckle needed to come off the car and be pressed out to install them. Which means you have to basically take apart the whole front end suspension. So there I was pressing the hub out off the knuckle assembly, it pops, I think I’m all set but when I look It pressed the snap ring through the knuckle assembly braking it. I know now that the hub needs to be pressed out of the assy. first, then the bearing can be pressed off. The helms was no help here. My question is where can I get a new / used knuckle assembly? Should I look into after market/ performance or maybe a GSR front swap?
