First of all, I’ll let everyone know that I live in NL, so any parts here will have to be shipped. I’ll list prices for the parts, shipping will be extra, and obviously depends on the combination of parts that you want to buy.
I’ll ship Canada Post ground unless you want it yesterday. I have a Venture one card, so there’s some small discount for that. Shipping from here to Ontario is typically pretty cheap to begin with. Anyway, feel free to pm me or call/text/e-mail about any parts that you’re interested in. I’m easy to get along with, and have no issues providing extra information.
I’m selling these parts because my engine has taken a dump and I’m about to foot the build for an expensive rebuild. By expensive, I’m probably going to be over 5K. So it would be nice to sell all these parts to help, but understand I’m not going to give them away because of this.
I’ve provided a link to many of the parts from their sites for anyone needing better pics/info.
Contact info:
pm
e-mail: thatguycole@hotmail.com
Call/text: 709-687-1413
H1 35W HID Kit - Kouki S14 lights
I bought this in a local GB this summer.
I installed them and they worked without issue all summer.
I literally lined up against a wall with my buddies Evo X last month, and although there was a difference, we were both amazed at the quality of the light for “chinese HID’s”.
$50
GTSpec Turbo Elbow
I took this from my GT2871R turbo, so it will bolt up to any t25/28 turbo. For an SR20Det.
http://www.gtspec.com/index.php?nav=products_category&pid=171&cat=111
MSRP: $199 USD
Asking $130 CAD
Megan Turbo Manifold - SR20DET
Literally, this is in the mail on its way to my house.
I bought it with a turbo setup, but am currently using a FullRace manifold.
I’ll sell either of the manifolds, I don’t really care which one I’m using.
According to his listing, the manifold has been “reinforced”, but I think they’re talking about the tabs on the tubes, and the bracket to tie the turbo outlet to the block side.
The Fullrace manifold is ceramic coated.
This manifold cracked on me about 2 months ago.
I spoke with Fullrace and with my welder, and we all came to the consensus that a bad weld on the base plate cracked, causing an exhaust leak.
The weight of the turbo assembly and the exhaust (no flex pipe) eventually caused the manifold to crack around the base plate due to fatigue.
I got my welder (He works with offshore stainless and duplex daily) to weld the manifold for me, and he told me it shouldn’t cause problems anymore. He used a good tig welder.
He welded it with stainless rod, but tells me that the material is a duplex, that’s why the welds don’t look real pretty. However I was there when he did the work, and we could see the penetration from the other side of the steel, so it’s a strong weld…just not very pretty.
Megan Manifold: $125
FullRace Manifold: OBO (their current manifolds retail for $999-$1425)
Megan
Fullrace
Turbo Inlet Pipe & Inlet Elbow
For the SR20DET.
Same deal as the Manifold.
Nissan products.
$100
GT2871R Wastegate Actuator
$80
Garrett GT2871R Turbocharger
Not selling the HKS wastegate actuator.
0.64 exhaust housing.
This turbo had shaft play when I pulled it, but it was still boosting to its full 18-20 psi. On the drag strip it was boosting 26psi peak.
Not sure what the etiquette is on selling turbo’s, as I’ve never sold one, but I’ll sell this if anyone wants to buy it.
If not, I’ll just use it until it doesn’t want to play anymore.
How about less than half price?
$600
S14 Cluster with pigtails
This is the original cluster that came with my car. 223055km’s
The backlight for the clock was working intermittently, so I replaced it.
The location where the backlight inserts wasn’t holding the bulb properly.
I tried putting a bead of solder around the base to hold the connection, but the backlight would still work intermittently.
The clock works fine, you just can’t see it at night all the time.
$40
AEM Serial Gauge
I unplugged it from the EMS and took it out of my car when I bought it, as I wasn’t using it. This was only bought and installed last summer.
The gauge is currently in the black face configuration.
I have the Silver bezel configuration to go with it, if anyone wanted to change colors.
You can cycle through and set min/max warn for 19 channels on the ems.
Boost/AFR/temps/knock/rpm/etc.
Cycle through and clear the max/min holds with buttons on the gauge.
You can also program the 24 led’s for custom colors.
http://www.aempower.com/ViewCategory.aspx?CategoryID=64
MSRP: $222 USD
Asking: $150 CAD
Autometer Cobalt Transmission Temperature Gauge
Brand new in box.
I bought this new, and never used it. It’s been opened to inspect, but never left my house or the box.
http://www.autometer.com/cat_gaugedetail.aspx?gid=3434&sid=4
MSRP: $70 USD
Asking: $50 CAD
Nissan purple top injectors
These came with the supercharger kit that I bought for my Maxima.
I believe they are SR 370cc, but that’s just what I’ve been told.
I sold 4 of them, these 2 are left.
One has a crack in the plastic covering the plug, but should hook up just fine.
$20
Bell Engineering (B.E.G.I.) FMU - Billet Aluminum
I bought this when I was piecing my supercharger kit for the Maxima.
Originally paid $250 for it, and only ever bolted it up for first startup.
My FPR blew up on startup and dumped fuel all in on top of my IM, so I went with the original Vortech setup for simplicity.
http://www.racetep.com/begireg.html
MSRP; $249 USD
Asking: $150 CAD
AEM FPR - With gauge
This is the FPR that broke its bladder on startup on the Maxima.
I bought the rebuild kit from AEM for $65 USD at the time (Last year), and rebuilt it. I haven’t used it since the rebuild, so it’s essentially a new unit.
I also have a fuel pressure gauge on the unit, that’s included.
http://www.aempower.com/ViewCategory.aspx?CategoryID=51
MSRP: $203 USD
Asking: $150 CAD
Aeromotive FPR - With Gauge
I got this in a trade local a while back.
As far as I know, it’s had very little use.
There’s a fuel pressure gauge included with it - Autometer sport comp 1-60psi. I think the gauge is worth $40 alone.
$150
Nissan Seat Belt Pads
The gf likes soft things…lol
She bought these when I had the Maxima, they never really got used
$10
Battery Main Kill Switch
Can’t remember where I got this, but it’s the same type thing seen on drag cars.
$10
S14 front/rear strut bars
I never used these.
Bought them, but my car was broke by the time they showed up.
$OBO
Nissan Knock Sensor
This is a VQ30 knock sensor.
I paid $90 for it.
Asking: $50
Garmin Etrex Legend GPS
Honestly, this was a gift from work that I never used.
I turned it on to download my location once, that’s about it.
Basically brand new if anyone is into that kind of thing.
https://buy.garmin.com/shop/shop.do?pID=173
They retail for about $150 USD
Asking $70
