Car is a 1992 honda civic, has a vtec d-series motor in it.
Symptom: Car loses voltage over a fairly short period of time, about a few hours and its dead.
Known:
Battery is only a few WEEKS old. With the positive terminal disconnected, it holds a charge as it should.
With terminal disconnected, the car runs fine and with with plenty of incoming voltage from the alternator.
With terminal connected, the car is losing voltage with the car being completely turned off. I thought there may have been an issue with wires from the stereo being disconnected, so i pulled the fuse, but the problem still persists.
Within a few minutes(5 or so) it drops a few tenths of a volt, so over an hour or two, its to the point where it just wont start at all.
^ Wow, thats odd… Alternator is causing a load? Hmm… If it holds a charge overnight without the alternator connected, just get a new one off ebay or a junkyard… Possibly on here…
werd, it is odd indeed. And the green plug isnt even connected, its just the wire that feeds the power back to battery for charging. I tried a different wire to connect from the alternator back to the fuse box too, same thing happens. Its gonna be the alternator.
